Blitz Nur-R Exhaust
Nissan-S14
Car: 95 Nissan 240SX SE
there is a guy on ebay he sells test pipes for any car for $35.
JJ240
Car: 95 white 240
as long as the flanges lined up that would be a great deal, its almost as cheap as just buying the parts and doing it yourself without the hassle
Nissan-S14
Just did a 1/4 mile with Blitz Exhaust, With stock I did 16.295with the Blitz exhaust my car ran 16.175
240_Keyy
Car: '90 240 Fastback
so basically it made you drop a tenth, that's nice. I have to put mine on as soon as I get it because my crappy stock exhaust rusted through this weekend and I have it held togetther with some thin tin sheeting, a "do not trespass" sign and some hose clamps.
it sounds worse than ANY honda I have EVER heard :(
Redline240
Car: 95 240sx
Ok guys, dont be so lazy and go to the Blitz-na site. According to them, the catback is known as Nur Spec R, and the axle-back is known as the Nur Spec. So based on the manufacturers site, all you guys with the catback have the same exhaust with 80mm piping. If it didn't say it on the box who cares, you just found out that you got a Nur Spec R!
Redline
Ace
Car: S14
Wow I have the Nur Spec R. Man I must have like a thousand horsepower now. You know when there is an R at the end the car is fast. Yaaaaaahhhhhhoooooooooo.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
krazy skwerel wrote:why does every one want a test pipe? are you all running leaded fuel? not only is it emmissions illeagal but it provides no back preassure. just get a hipo cat a little more money but provides everything you need. just wondering.:alcoholic
Backpressure is never a good thing. Even on an NA car. Silly hotrodding myth.
Decreased exhaust velocity is a bad thing. You want your exhaust to exit the car as fast as possible for optimal performance. If you get to big of an exhaust on a NA car, then the exhaust pressure (pressure increases inversely to area) is to low to create a sufficeint velocity. If it is too small, then you have too much backpressure (exhaust is too small and restricted exhaust flow). Therefore backpressure is always bad. You want the exhaust to flow as fast as possible, with the least amount of backpressure, regardless if it is turbo or NA.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Nissan-S14 wrote:I just baught and installed the Blitz Nur-R Cat Back Exhaust, Just wanted to say by far the best Exhaust I have ever seen, The way that it is made, beautiful, The sound is amazing doesnt sound like crap like most exhausts do, I do tell from experience, I have owned Greddy, Stillen, My friend has Apexi, and HKS, Nothing comes close to Blitz the way it looks or sound wise. Its little expensive but well worth it. Dont have HP ideas, I dont have the dyno, But im going to English Town this weekend, My time was 16.2, will see what ill run with the exhaust.
Good to hear you like it, we just ordered a bunch of those, and they should be here any day (hopefully tommorrow). :)
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
ok so the backpreassure thing isnt legit. but still if you run on the street and have emmissions then i think a hiflow cat is better. perhaps because im lazy and wouldnt want to change it out every time i got it checked or something. but is there anything that shows hi flow cat would really hinder a car that much? just seems like a lot of work for something like that.:cool:
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
krazy skwerel wrote:ok so the backpreassure thing isnt legit. but still if you run on the street and have emmissions then i think a hiflow cat is better. perhaps because im lazy and wouldnt want to change it out every time i got it checked or something. but is there anything that shows hi flow cat would really hinder a car that much? just seems like a lot of work for something like that.:cool:
On a NA car, you are not going to notice any difference at all between a high flow cat and a test pipe. Probably not even any with a stock cat. Maybe on some cars, however, Nissan's notorious for having decent high flowing cats from the factory. Turbo'd cars are a different story.
You *might* see a HP or 2 gain from going from OEM cat to a test pipe. High flow cat would be inbetween there somewhere. Not worth the illegality IMO.
krazy skwerel
2005 Honda Accord
thats cool.:cool:
Nathan
EZCheese, isnt one of the benefits of higher exhaust gas speed because it helps scavenge the exhaust from the combustion chamber and hence allows more fresh a/f in resulting in more power? At least this is my understanding with NA cars...hows it work for turbo applications?
Exessive26
Car: AutoX, Drifting, Biking
I was trying to get the Blitz Nur-R Exhaust but the wait waswas like 8 weeks. And so I went with the HKS. I was was notdisapointed, the build quality is first rate. And I used a3in Cat, becouse it helped with the low end power.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Nathan wrote:EZCheese, isnt one of the benefits of higher exhaust gas speed because it helps scavenge the exhaust from the combustion chamber and hence allows more fresh a/f in resulting in more power? At least this is my understanding with NA cars...hows it work for turbo applications?
Same applies to turbo cars. The only thing is, on a turbo car, since you are forcing the air out of the car at a much quicker rate, the point when you need a smaller diameter exhaust is much higher. To the point you basically won't ever have that problem. Unless you are trying to run like a 12" mandrel bent exhaust with a T3 :) LOL
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Exessive26 wrote:I was trying to get the Blitz Nur-R Exhaust but the wait waswas like 8 weeks. And so I went with the HKS. I was was notdisapointed, the build quality is first rate. And I used a3in Cat, becouse it helped with the low end power.
8 weeks? Really? We have them in stock!
Exessive26
MAN! I tried every where, and they all said it was a back order item. OH well
240_Keyy
lol, Torry you make it sound like they have been sitting around for weeks :)
you and I both know when you got them :D
Post pics for us...
Nissan-S14
240_Keyy wrote:lol, Torry you make it sound like they have been sitting around for weeks :)
Post pics for us...
i have the pic, installed on my car, will post it when i scan it
Daunttless
I"m installing my software now, I'm gonna put some more pictures up on the website. : ) We've got a few pictures of Keith's (240 Keyy's) exhaust out of the box. : )
Daunttless
240_Keyy
ok, Now I want that put back in the box EXACTLY like it came out! (after you put the fuel pump and FATT in there of course :D)
so purty and shiny.......
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
Yes but I wanna see the exhaust ON the car :D
s14mc
More pics
Stee Flo
since its 80mm piping would it be too loud on an na car?
Ace
Car: S14
If your going to swap to a SR or put on a turbo then the exhaust will work for you. But if your going to stay NA then get a 60 mm exhaust. There are a lot out there. Yes it will be very loud.
240_Keyy
this exhaust is hella flunking loud!!! That and I lost a buttload of power down low. I definitely do not recommend this for an NA car, but it should be Uber pimp for a turbo car...
Ace
Car: S14
240_Keyy wrote:this exhaust is hella flunking loud!!! That and I lost a buttload of power down low. I definitely do not recommend this for an NA car, but it should be Uber pimp for a turbo car...
Much agreed. BTW how is your swap coming 240_Keyy?
240_Keyy
The swap has hit a bit of a wall so to speak. I have 30 pages worth of papers due by this coming thursday, so I have less than zero time to work on the car. Next week I am free though, so I am gonna pull the motor out of my car, do the wiring andd start the swap. I have to have it finished by May 18 cuz I have a thing to go to down in Houston.
if you want pics of the stuff, check the link dealie in my sig...
Nissan-S14
I Dont know about loosing power, the exhaust gave me .2 - .3 quicker ET, and my trap speed went up by 2mph.
240_Keyy
Well I am talking about low end power, my high end is GREAT, the car pulls all the way until the fuel cut. I would say my entire powerband shifted 1200rpm towards redline. Where I used to have power at 3000 I now get it (and probably more) a little over 4000.
