OEM Porsche doesn't mean much. Porsche is a low budget builder, but they will tend to spend money where it matters. Unfortunately the turbochargers were good in the 80's but turbos like the K27 and K26 are no match for a modern day equivalent. They will make power, but you will find greater efficiency with a Garrett turbocharger.FattyMcBaggins wrote:I don't know what would be considered "acceptable" spool for the power numbers I'm shooting for. I'd like to have full boost around 3500, but I don't know if that's way off or something. As far as the KKK turbo, I figured if it's good enough for OEM Porsche, than it can't be too bad. I may swap turbos somewhere down the road, but for now it will suffice. I like the convenience of a turbo kit, because I'm terrible about forgetting to order certain parts. And since my car is a daily driver, downtime means time off of work, which means less cash. less cash= Anybody have experience with these kits?
No, the 71 wheel will push alot of pressure at a moderate flow rate. I would honestly go with a GT3071R in a .63, it has better wheel matching.spider_slayer wrote:does the turbo max out at 16psi? cause 450 to the fly i believe is something like 380 to the wheels.
That's what I have coming. I can't wait.HardcorePS13 wrote:No, the 71 wheel will push alot of pressure at a moderate flow rate. I would honestly go with a GT3071R in a .63, it has better wheel matching.
It's a sweet turbo.Dori Dori wrote:That's what I have coming. I can't wait.
Spool up is about 400 RPM between the two choices.FattyMcBaggins wrote:Man...it's hard to decide whether the extra power is worth the loss in spool between the 2871R and the 3071R. Damn you decisions! Since it will be daily driven, I think I'm going to get the Enjuku "Peakboost setup kit" with the Gt2871R. I think that spool will make it a little more fun on the streets. If worst comes to worse, I can always upgrade turbos. Is the Peakboost manifold a good choice? Or should I go with the Full Race?
BTW, you guys are awesome. Thanks for all of the help. That 30R looks like it'd throw you into the seat once it spooled up!
EDIT: Any dyno sheets of the Gt2871R in the .63 trim? I'd like to compare power bands a bit
Summit RacingFattyMcBaggins wrote:oh, we're only lookin at a 400rpm difference?. I was under the impression it would be about a 1000 rpm difference. Hell, I'm going for the gt3071r in .63 trim then. No doubt about it. You guys rock. who's a good supplier for stainless turbo lines?
Difference in lag will be minimal. Might even be less than the guesstimated 400. They have the same turbines and better matched compressors.FattyMcBaggins wrote:Hm...I'll be arguing with myself for awhile over which I'd like more, the quicker spool or more peak power. That extra power of that 3071R WOULD be fun, but it seems like it'd feel like FOREVER waiting for it to get there. It will be a daily driver though. The nice power band of the 2871R will rock. I'll probably pick that one. Now, what else will I need for all of this stuff to work together correctly?Peakboost top mount manifoldGarrett GT2871R .63 with a T3 flangePeakboost 3" downpipepeakboost dumptubeTIAL 38mm wastegate700cc or 850cc injectorsZ32 MAFstandalone or Enthalpy tuneIs that it? Do I need some custom turbo lines?
Modified by FattyMcBaggins at 9:23 PM 1/29/2006
The turbines are not the same. The GT3071R has an 84 trim or 90 trim wheel with a 56.8mm major diameter. The difference in turbine flow is notable.Dori Dori wrote:Difference in lag will be minimal. Might even be less than the guesstimated 400. They have the same turbines and better matched compressors.
Hmph, could have sworn that Enthalpy told me the 4 bolt gt housing on either turbo shares the same turbine. I can't find the info on the Garrett page either...they list the same turbine for both housings w/ certain a/r's and no listing for the GT housing w/ the .63 a/r (unless I'm looking in the worng spot).HardcorePS13 wrote:The turbines are not the same. The GT3071R has an 84 trim or 90 trim wheel with a 56.8mm major diameter. The difference in turbine flow is notable.
Dori Dori wrote:Hmph, could have sworn that Enthalpy told me the 4 bolt gt housing on either turbo shares the same turbine. I can't find the info on the Garrett page either...they list the same turbine for both housings w/ certain a/r's and no listing for the GT housing w/ the .63 a/r (unless I'm looking in the worng spot).
Depends... typically that smell is from catless cars that have poor running conditions or are running on cheap fuels. You can smell a difference between exhaust that has been scrubbed by a cat.FattyMcBaggins wrote:I didn't know that it goes all the way to the exhaust. I was planning on running a high flow cat, but I guess not! Is it true that running with out the cat makes your exhaust smell super nasty?
