well.... i was only able to get to the water pump today, got a bit lazy after that to mess with the P/S reservoir, so on with pics and captions...
sitting after two nights, and a top off on the P/S res... coolant and P/S fluid=FAIL....two shots of where my coolant is leaking....my two water pumps... good one off the old motor on the left, bad one off the new motor on the right.... grooves cleaned and all...so as your water pump goes bad, coolant will leak out of this hole.... for your informationz... the hole directly on the bottom of the pump...high temp RTV FTMFW!!!!i put my thermostat back in, the one that came on the motor was stuck, so i sourced it off the old motor, and used a wire brush bit on my drill to clean the neck... and replaced the water pump... finished shot... not TOO TOO much excess RTV...add the coolantz...Bleed the coolantz....this is just a neat shot, coilovers are sweet, no more jacking up one corner of the car at a time anymore lol... not a lot of suspension travel.... sorry, just now learning the joys of coils.... and yeah, i used TWO jackstands....
anyways, final result is awesome, my car idles a s*** load better (probably due to a working thermostat keeping the engine @ operating temp), albeit @ 1,150rpm.... no more misses, skips, or sputters, not telling what it'll do @ 800rpm... but for now is good...
i took it for a little test spin, to see if she'd get hot (i was worried it would, cause i didn't really know the status of the old thermostat from the old motor)... the needle sat JUST above the C with a small gap and stayed there, never got higher, or lower, ran a bit smoother (i guess the coolant temp sensor wasn't reading cold all the time), and idled good....
next small thing to do is to figure out my P/S leak... easy....
video of good running motor, for all who're interested.... (for those who said it would never run right JOSH)
http://www.youtube.com/watch?v=lqKHT8kMwF4
like always, more to come!!!!
Modified by BlackZenki82 at 1:41 PM 2/21/2009
