Alright guys it was sunny today so i decided to do part of the process today so here it is blackening the headlight.
Just a little info if your going to do this its a time consuming process. If you dont have the guts to do this then i recommend you not.
Gather your tools. A Flat head screwdriver, a star screwdriver, a 10 inch socket and ratchet. A high gloss high temp black paint, primer, and i used black silcon (i used black gasket silcon), masking tape.
First off you will need to take off the bumper. 8 clips at the top, 6 screws at the bottom, and a few clips underneath as well. Follow this.
http://www.nicoclub.com/articles.php?id=293385
once you have done this you should end up with the head lights now
STart Removing the bolts with the 10 in socket and ratchet and use the star screwdriver for the screws theres 3 but i only had the picture at 2 sorry guys but the 3rd is right around there can't miss it.
you remove the headlight and wire off the holding clip and all the bulbs and remove the 2 star screws at the back of the headlight housing
After your done with that your going to want to set the oven preheat at 350 which i did make sure you have a sort of pan and foil wrap underneath on the parts on which it leans on so those dont melt. when the oven is finished preheating put it in for about 6 minutes.
While your waiting make yourself a sandwich lmao
.. make sure you have ur space provided to pry open the headlight which you must immediately after taking out make sure your wearing some sort of gloves to protect from the heat its hot .
Keep prying it open untill its fully opened at which you'll end up at this point
Now you'll remove the 2 star screws on the inside you'll see them and you'll separate the pieces to end up with this remove the big orange thing you didnt want
Begin sanding down the chrome pieces i used a 320 fine sand paper to sand it down a little bit and mask the areas in which you dont want painted and have your primer ready in the paintin area although some people painted the chrome section off the yellow turnsignal area i left it chrome to distinguish it from the rest
Now you begin to primer and paint i used 2 coats of primer and 2 coats of paint about 15 minutes in between coats of primer and bout i left about 25 on the paint between the coats .
and final product of paint
Now removing the masking tape and put the pieces back together put the black piece connected with the headlight face then the small chrome piece screwed on behind it clean out the dried clean from the back of the housing so you can re insert the front with the back piece
Your going to want to bake the back piece of the housing in the oven again for 6 minutes .. again once done with this makesure you have ur silicon in hand and ready to put it together begin putting it together now it should put it silcon the edges of housing insert the 2 pieces together and mold back the black edges together and apply a thin strip of silcon between.Sorry i dont have pictures of this process it was only me working and tryin to take pictures and doing this part is a hassle, didnt want to risk rebaking it.
let it dry for a few hours reconnect the headlight, lights etc, bumper and the end result will be
Will update pictures hopefully tomorrow
Modified by kanejuice at 6:25 PM 4/29/2008
Modified by kanejuice at 2:44 PM 4/30/2008
