Black box blow Intake tube?
benz88
Car: 91 240sx
I looked in the FSM and can't seem to find a pic. Its under the top rad hose and intake tube and Connects to the bottom of the Intake. In the circled part of the pic is the area of it.
biggie
The box that attaches to the bottom of the intake and is connected to the fan shroud/radiator? What about it? It just is made to reduce noise in the intake. Can be removed, just have to plug that hole on the intake.
benz88
Car: 91 240sx
biggie wrote:The box that attaches to the bottom of the intake and is connected to the fan shroud/radiator? What about it? It just is made to reduce noise in the intake. Can be removed, just have to plug that hole on the intake.
I didnt notice what It was connected to. For some reason I thought it was connected to the Intake Mani haha. Thanks I'll remove it, Im trying to slowly clean up the bay
(that pic is not my bay fyi)
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
the black box located below the radiator hose connected to the front cover and underside of the intake manifold is the housing for your pcv valve...also known as an oil separator or catch can.
benz88
Car: 91 240sx
Thank you. I'll be adding a new catch can I guess
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Improves VE as well. Lots of cars come with them, it's to improve WOT response when you suddenly snap the throttle.
EDIT: Moso, are you sure? When I replaced my rad and the hoses, it wasn't connected to anything else...
moso
90 240sx ka24de RIP
yeah, I'm pretty sure on this one. the box bolts onto the front cover just below the thermostat housing. mounted pointing to the firewall on the rear of the box is the pcv valve. the valve connects to a metal runner with 4 ports that attach to 4 nipples, one under and just behind each of the injector ports. It is rarely changed because of its terrible location, which results in many bad valve cover gaskets ~.~ ! I nixed mine when i stripped the intake manifold to prepare it for boost. this thread shows a beautiful picture of the valve and its housing about 5 posts in where-is-the-pcv-valve-location-on-a-95 ... 95487.html
EDIT: I never actually removed the pcv, its now plumbed into a catch can that will be routed to the intake pre-charger. I removed the nipples on the intake and plugged them with threaded plugs.
asoomal
I think you're talking about a different box...
moso
90 240sx ka24de RIP
Totally possible, although I cannot think of another mysterious box in that area.
biggie
The black box he's referring to does it connect to anything except for the intake tube.
Super Ertoy
Car: 1991 240sx
any response to this yet? I'm wondering too. I was gonna put in an aluminum intake then i noticed the stock pipe had this giant port that connects to that box adjacent to the radiator shroud. haven't had time to get underneath to get a good look but its definitely not breather seperator.
Super Ertoy
Car: 1991 240sx
Alright, so it bothered the hell out of me....heres your answer:
Just another closed black box...no connections other than the bung from the intake pipe. 3 screws that holds it. Bottom left screw has a bendy clip.
benz88
Car: 91 240sx
Yeah I ripped it out lastweek! I was going to take pics. Now they know, Thanks! :)
asoomal
I'd keep it...like I said before, it does more than just quieten the intake sound.
