u hy huys i just wanted to know whats the real deal with the PCV valve what does it do ??is it important??zest2live wrote:It's screwed into the back of an aluminum "breather separator". The breather separator is bolted to your lower timing chain cover right below your thermostat housing.
Best to come at it from below.
Edit: I just pulled my front timing cover. You'll probably save time/aggrevation if you remove the alternator in order to get to the PCV valve.
Modified by zest2live at 12:38 PM 11/28/2007
This article explains what it does and why it's important.http://en.wikipedia.org/wiki/PCV_valverps-13 wrote:u hy huys i just wanted to know whats the real deal with the PCV valve what does it do ??is it important??
It's the stock intake. You can see the whole thing in an earlier post (this thread) where I show how buried the PCV valve is.Dcrprez wrote:sorry to intrude but what intake is that in your sig???
Thanks! If only I could fix the oil pressure (look for "oil pressure" thread).JDS Performance wrote:thats a nice/different looking KA
