93RPS13 »
https://forums.nicoclub.com/93rps13-u3935.html
Sat Jan 03, 2004 4:57 pm
sorry if i am h-jacking but i have a question on the Z32 30mm calipers, what rotor size does it take because if you convert 30mm it is 1.1811 inches, so will 1.2" rotors work with these calipers?
if they can then i think you can fab up your own kit using a Z32 30mm calipers, some wilwood 2 piece rotors or 330mm x 30mm 2p rotors, then you can proably figuare out the mount brackets or proably a machinest can then you need some 17 or larger
also does anyone know how high is the hat on a 300zx 30mm rotor, like if you layed a 300zx 30mm rotor on the ground, then lay a ruler on top of the hat, then stand a ruler on top of the surface area of the rotor and measure, or this wouldnt matter??
