For some reason or another, the CPs seem to expand a little more than the wiseco units (could be wrong). In 1999, I had one of the first, if not the first set of wiseco pistons custom made here in the U.S. for the CA18 in which they took one of my stock pistons and copied it. That resulted in 4 broken oil squirters (stupid machine shop) and then three of those pistons were killed using a guinnea pig (the first one for them) 1988 nissan pulsar ecu re-mapped by Jim Wolf technology.
So I purchased the CPs in 2003 or 2004 (don't remember), had the cylinders professionally honed, installed them and had done pretty well with them for years to come. But over the years, that engine had been serviced on different occasions (new rings) to include hone after hone after hone, but never appearing to need an over-bore due to the bores being wiell within the manufacturer's specifications. The CP pistons were noisy when cold, but will eventually quiet down somewhat after the engine reached normal operating temperatures. The build before I had the engine bored over was the last straw because the compression was all over the place. So I tested all cylinders cold, hot and also checked it while the pistons were cooling down and the compression numbers were constantly changing which basically showed me how much these pistons expand and shrink in a short amount of time. The wiseco pistons were actually quieter than the CPs, but it could be just wear on the bores
