Best Wideband??
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
I am currently shopping around for a wideband unit. I have read and seen many but I am looking for some real life feedback. Let me know some opinions.
Rich
Broadfield
Car: 1992 240sx
I am personally going to go with the Zeitronix. I like the rectangular display setup on the ZT-2 and it's something that I can modify and put in a spot that will make my interior happy.
Here is a test on most of the popular brands out there.
http://www.newtiburon.com/foru...09436
Koshin
^^^^whats up man. I saw the Zeitronix, and Im getting ready to read the article you posted...Im liking the Innovate LM-2 right now...Im gonna readthanks for the input
Rich
redsx13
Car: 93 240sx 03 350z
I am running a tomei, but they ar pretty rare. works very nicely.
Emperor_Tha
I got an autometer wideband
Has adjustable stoich reading for different gas (pump,meth,propane,etc)Has full throttle afr feedback when the brown wire is connected to the throttle
And there is a connector which can be plug into standalone
When I first tune my safc by import intell. He likes my gauge over his aem because it reacts faster. (street tune)
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
91SilviaKs wrote:Im liking the Innovate LM-2 right now
That's a nice unit if your not going to do a permanent install. I've had a Zeitronix, LC-1, AEM, and a DIY one. They are all roughly comprable because they are using the same sensors.
I have heard a LOT of problems with the LC-1, but I have never had any issues myself.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Ive worked with the Zeitronix and Innovate units. Both worked nicely, and had decent displays. Ive also used the F.A.S.T. single sensor unit, it worked well, but the display was clunky, and kind of ugly.
Currently I am using an AEM all in one UEGO gauge. I like it a lot, it offers pretty much all the options of the more complicated units, without all the boxes and wiring.
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
I have a NGK AFX. It's cheap and I have no cmplaints. It has a rectangular digital box.
CMG
Car: 1989 240sx Hatch w/ Redtop
AEM uego, or buy my Tomei A/F gauge.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
I run Innovate right now. Majority of the Supra guys run PLX.
pauliedrft
Car: 91 240sx
Aem for me . like the read out and if a friend of mine with a 1000 hp supra uses one i think there pretty good .. (as he had suggested me to get )
Koshin
descisions, descisions......thanks for all the inputs guys. To you cats that have used the Innovate units, is the software a descision maker?? Has anyone used it?? Just wondering, never seen it personally
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Innovate's software is actually one of the more powerful ones out on the market. I'm not sure if there is a plug in out there to datalog from a consult port or not, but it can do a hell of a lot more than just tell you what your afr is.
nismonet
what is the difference between the AEM wideband and the AEM wideband UEGO?
Koshin
the converted wrote:Innovate's software is actually one of the more powerful ones out on the market. I'm not sure if there is a plug in out there to datalog from a consult port or not, but it can do a hell of a lot more than just tell you what your afr is.
thats what I gathered...I think that has made my descision...thanks
pauliedrft
Car: 91 240sx
nismonet wrote:what is the difference between the AEM wideband and the AEM wideband UEGO?
( Im cheating this is direct from the AEM website .)A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
and the controller by itself Wideband UEGO Controller Modules FAQs...
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM's Wideband UEGO Controller is available in single- and dual-channel models for everything from four-cylinders to V10s, and is the most affordable UEGO sensor controller available. This unit has a very low current draw, and features both 0-5v calibrated output and 0-1v calibrated output. This unit works with virtually any stand-alone engine management system.
hope this helps
goalguy02
Car: '92 240
91SilviaKs wrote:descisions, descisions......thanks for all the inputs guys. To you cats that have used the Innovate units, is the software a descision maker?? Has anyone used it?? Just wondering, never seen it personally
I use the Innovative unit. The program is nice and easy to use. I haven't used any other setups so I don't know how it compares, but I find it easy to use.
