Best Wax
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
lybrian1
Car: 2008 EX35
i want to polish my EX to make it look better then new. i just bought a buffing wheel and buffer. whats the wax type of wax and brand of wax out there?
what brand of wax do you personally use?
cjre1
Car: Infiniti EX35 Journey
I use the new Meguiars brand.
NXT Generation® Tech Wax® 2.0Item # G12718
http://www.meguiarsdirect.com/...12718This is a really good wax. I have tried about 40 of them and this one is the best.
Hope this helps.
rubbersidedown
Car: Infiniti EX35. Black & Chestnut. All options but Tech Pkg. RWD.
cjre1 wrote:I use the new Meguiars brand.
Hope this helps.
Ditto - I've used it and love it - easy on/easy off. There is also a NXT detail spray for use in between applications. Not really a "wax", but a nano-technology sealant, I believe.
marlin29311
Car: 2008 Infiniti G35x
I use the regular meguiars gold class wax, and then the ultimate quik detalier after every wash. I wax once every 3 weeks, and clay bar once a quarter.
Buffing wheels aren't that great...you do a better job by hand, even though it takes longer.
lybrian1
Car: 2008 EX35
thanks
cjre1
rubbersidedown wrote:There is also a NXT detail spray for use in between applications. Not really a "wax", but a nano-technology sealant, I believe.
I used this once and it left a haze on my car.
sluday
Car: 2008 EX35 AWD Journey Moonlight-nav-premium-tech-lux
WAX....what is that ?
tazdevl
Car: EX35 Journey AWD Plat Graph/Stone - Fully Loaded
If you want the best... you want Zaino.
rubbersidedown
I've never had that problem, and my Ex is black. I use the liquid, I let it dry (20m) and it buffs off easily and leaves a brilliant and deep shine.
BTW, I looked at the NXT bottle and its says "wax", but is further described as a synthetic polymer, and that's over my pay-grade to explain. But, it really works for me. Used it on my daughter's black Subaru as well and had the same excellent result.
cjre1
Wax is good especially if it has been made with a synthetic polymer. This is the new technoloy. You really have to read that it does. Mostly all waxes look the same, but work differently. I also use a name brand that has been proven.
lybrian1
Car: 2008 EX35
im gona get some NXT Generation stuff and a new can of Nu finish because i left mine outside over the winter and became all liquidfied.actually i left all my car car products in the garage over the winter and forgot about it. now i have to throw everything away.
cjre1
Dang that sucks. At least in CA, you do not have to worry about the weather at all. OK, the heat, but it is better than freezing.
I tried NU and think that NXT generation is better. All are about the same price. Good luck.
lybrian1
Car: 2008 EX35
i have to restock on everything. i left everything outside. even my interior products (leather wipes, dash wipes) have dried up, useless expensive paper now. scratch repair products are liquidfied. nothing has made it through the harsh winder in my garage lol. not sure about the car wash soap it still looks good.
cjre1
Sorry to hear this. Dump the soap. This is huge for the car. It can go bad.
lybrian1
Car: 2008 EX35
soap still looks good though but saving a bit of money isnt worth the damage it may cause so ill throw it out. but dang feel dum for leaving it all outside.
cjre1
Good choice, soap is cheap. We all learn from our mistakes. It could of been worst.
gofast24
Car: 2009 FX50S / All Options / Black w/Wheat
lybrian1 wrote:im gona get some NXT Generation stuff and a new can of Nu finish because i left mine outside over the winter and became all liquidfied.actually i left all my car car products in the garage over the winter and forgot about it. now i have to throw everything away.
Move to Atlanta and you can leave your wax in the gagage over winter (LOL)
cjre1
Hell move to California and you can leave your wax outside, inside, where ever you like.
lybrian1
Car: 2008 EX35
cjre1, i got the NXT Generation® Tech Wax® 2.0 like you said. cost me 30 bucks. havent used it yet. the sponge inside is for the application right? or is it to wipe off? would i be about to use this wax with a buffer wheel?
cjre1
Cool man. You picked a good choice. That is the applicator pad for the wax to put it on. It is nice. I use the purple side. I think it has two sides, right one green and one purple. The purple is the softer side. You can use any side.
I use cloth baby diapers to take the wax off. You want to use the softest material cloth that you can find to take the wax off.
Good luck.
rubbersidedown
Yes, use the applicator to put it on. Whether you use a machine or remove by hand, since you've gone this far into the detailing issue, I strongly suggest getting micofiber towels specifically made for wax removal. Some guys use a certain cotton towel, but cut off the stitched edges to prevent scratching or scaring the finish you applied. Check out Autogeek.com for some super suggestions, insights and discussion forums.
cjre1
Actually micro fiber cloth gums up and does not easily move on the car. It does work, but with some elbow grease. Here is what I do:
1. Wash the car, very well. Twice. Once with a lot of soap, like a foam bath. Then I use a power washer to wash it a second time, with little soap coming out of my 300PSI washer.
2. Rinse the car very well.
3. Dry the car with a 100% Chamois. It is leather is a type of porous, non-abrasive leather. In the 19th to the first half of the 20th centuries, it was very commonly used for gloves for men and women. It is commonly used as a drying material or polishing cloth.
4. Park the car in a cold area, garage, carport, etc. Make sure no sun is shinning on it. Make sure the entire car is cool to the touch and is dry.
5. Wax, either by hand or a machine. Do not burn the wax in with the machine. Be careful. You can read how to do this from the machine instructions.
6. Let the was dry completely, minmum of 20 mins. I always wait 4 hours. The longer you wait the better. Sometimes, I wait overnight, only do this if the car is in an air tight garage like mine. I have a special garage.
7. You can take the wax off either by hand or machine. Be careful not to burn it with the machine. I use the machine, then after that is done, I wipe the entire car with a large micro fiber cloth. I always use a brand new one. If you take the wax off by hand, I use 100% cotton cloth, lint free or a microfiber, but remember what I told you about the micro fiber.
All is good not matter, if you follow the steps. I hope I didnt leave out anything.
lybrian1
Car: 2008 EX35
thanks
cjre1
You are most welcome. I hope this helps everyone what I post.
boriskey
Car: 2008 EX35 RWD journey + premium
thanks a lot
cjre1 wrote:You are most welcome. I hope this helps everyone what I post.
thanks a lot!
scottt
Car: 2009 Infiniti EX35 RWD Journey
I don't use wax, it goes away too fast. I applied a good paint sealant, looks great and provides protection for at least 6 months. Scott
npeckio
Car: ex35
i use Klasse products with very good results, the "all in one" and then the glaze...2 coats. it will get me through the winter nicely. i also due the wheels as well.
AWGD8
Car: 2008 EX35 AWD JOURNEY
I`m a big fan of Zaino product:
Z2 PROZFX Flash Cure Accelerator AdditiveZ-6 Ultra Clean Gloss Enhancer SprayZ-CS Clear Seal
But now I realized that it is very time consuming to apply , wait, buff the whole car. It took me 2 to 3 hours to finish the ex35 exterior only.
This time I decided to cut corners and bought Meguiars NXT Generation® Tech Wax® 2.0
-Washed the car(touchless automatic carwash)-air dry -sprayed some Mequire quick detailer or Zaino Z-6 Ultra Clean Gloss Enhancer Spray- applied NXT GEN TECH WAX 2.0-waited to haze- Buffed a bit-sprayed Zaino Z-CS Clear Seal to seal it.
The whole process took me 1 hour including wheels and tires.
If I have enough time, I could have clayed the car first for ultimate exterior polishing result.
FYI: It took me awhile to decide if I would get the NXT 2.0 or the Turtle wax ICE POLISHhttp://www.turtlewax.com/main.taf?p=2,1,1,1
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
Check out >>> http://www.autogeek.net/index.html
It's the best site for Detailing Stuff... and their Forum to go along with it >>> http://www.autogeekonline.net/forum/
EXceptional
What I just ordered and got from AUTOGEEK's...
My Griot Buffer (the new and improved version)
The Tool Kit and Spare Brushes that come with the Griot Buffer...
The Manual that comes with the Griot Buffer...
My 3" Griot Buffer for tight spots...
How both of them fit into my new DeWalt "eBay Special" Bag...
This Bag has a couple of Interior Side Pockets...
Two Wash Pails I ordered from AUTOGEEK, one Red and one Clear. I plan on using the Red one for Soapy Cycle and the Clear one for the Rinse Cycle.
Two Black Grit Guards... that stack up one over the other, in each Pail.
Two Red Grit Guards... that stack up one over the other, in each Pail.
Two Black Grit Guards installed in my Clear Pail...
Some of the Towels I ordered. The Green MicroFibre Towel on the bottom is called the Guzzler and has pockets for your Hands to go into to help you hang on to it as you move it around. Supposedly, one will do the whole Vehicle without wringing it out, ever. The item on top is my Micro-Fibre Apron with built-in Cord Loops.
My 6.5" CCS Pad collection and Spray Pad Conditioner and Spray Pad Cleaner...
My 6.5" Pad collection called the Kompressors...
My 3"-4" Pad collection, Polishing Pal and a few other random 6.5" Lake Country Pads and Kompressors...
32 oz Bottles of Meguiars #105 & #205...
Wheel Wax and Foam Pad Cleaner...
Black Again, 3M Wax, Wolfgangs Deep Gloss Paint Sealant #3.0...
Griot Handbook...
Griot Detailing CD...
Other reading materials provided by AUTOGEEK...
I think I'm ready to get started...
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
