All you're going to get with this thread is most likely forum opinion.
Nico member: "I have Brian Crower! So BRIAN CROWER IS THE BEST!"
You probably just need to alot of thread searching, in the SR section there is a CAMSHAFT Thread for SR20DET. Also, dont be afraid to search other forums. Knowledge comes from the desire to learn. If you want to learn. You will. Spend some time.
Here:
zerothread/210484
My non-biased opinion, Supertech, Brian Crower, HKS and Toda all make great products.
I was recommended to use SuperTech Valvetrain Components and HKS or Toda Cams with Tomei Solid Lifters and OEM Rockers. This company who recommended this, as far as I know has the highest revving SR20DET.
I personally would like to use a full HKS Head System with SuperTech Valves and Guides and HKS Cams. Not stating it as the best, just what I would like to use.
Good luck.
Modified by CoupedUp at 10:49 AM 3/12/2008
