yeah thats true. martin had my car revving to 8200 but it was so impossible to keep a slide without spinning out. i didnt really feel like i had good torque except when i was between like 6 and 8 grand, taht hard to keep ahold of that torque band when spinning the tires for drifting, you know what i mean? i think the a/r on the pulsar was actually too big, so i wouldnt wanna go bigger, and i def don't want more lag. im going to be doing a vmount setup this time to decrease lag as wellthemadscientist wrote:The spike you feel is likely the turbo coming on boost. A bigger turbo than the S14/GTiR turbo will take slower to spool and support your power goals but when it comes on it comes on. You could get something with a larger A/R to increase lag but that seems counter productive. Most people want as much time "under the curve" as possible. I like that kick in the *** when a turbo wakes up myself. Even my E that was substantially larger than the S14 turbo it replaced would hit hard.
You've gotta be running 14-18 lbs of boost to really wake the GTIR turbo up.....but not with 370's obvously. I'm not suprised you werent impressed. I would upgrade the fuel first....bump up the boost.....then report back =Pjrsink wrote:So im rebuilding the ca, after a buyer on here flaked out on pickin it up.so im gonna give it another shot.my whole block is getting rebuilt atm with new bearings and getting compltely balanced. im contemplating ordering a lightweight flywheel.will be running on my megasquirt II v3 setup already installed and used to get 223 whp at 8 pounds of boost with a pulsar gtir t28, fmic, walboro, stock? 370cc injectors, and wideband.
this dyno does not show torque just hp, but u get the idea. very spiking torque curve, I WANT A MELLOW TORQUE CURVER WITH PLENTY OF POWER!
i would like about 300whp, so i will be upgrading injectors but I am unsure what turbo will give me the most mellow torque curve for drifting it. : ) thanks guys, your input is greatly appreciated. sink
i sold it lol. i think it was the big a/r that was making me not like it. it felt a lil laggy, and yea it blasted off when it hit 4-5k but, i dont want to BLAST OFF, i want consistent torque/mellow curve. im gonna get arp head steads and a new headgasket, now that ive recently read about cas going up t0 600 hp on stock internals, bc the rods are forged. thats f**kin awesome. hmm, so i need a turbo capable of 250-400 lol, and a mellow torque curve lol... im still researching. andone more thing, when we talk abouty a/rs, are we talking about turbine housing a/r or compressor a/r?? just to get it straitr34 gtr wrote:Don't you have a GTiR t28 on there already? That turbo would be fine for the job.
so in comparison between your tubro, a 50 trim with a .63 a/r,and the the one mentioned above (Turbonetics dual ball bearing T3/t04 50trim .48 A/R ),the turbonetics will have less lage bc of the smaller a/r correct? bigger a/r are better for more flow, but the result will be more lag tho? and probably a steeper torque curve in mid to high range power (bc of increased flow, like a pulsar t28 that i was unhappy with)??hope i dont sound like a newb, im not, just kinda with turbo numbersKEMP wrote:go big or go home, haha
i like my 5otrim with a .63 a/r spool is very quick for a 50trim, external gate helps too, i like it, but im going for power, its a ca, torque is kinda low... but its a ca, rev it out like its been designed for, 8k + all day
Time out.jrsink wrote: now that ive recently read about cas going up t0 600 hp on stock internals, bc the rods are forged. thats f**kin awesome.
. im getting the t25 this week.i would like to max that out and add bigger injectors like 440s or 560s from an evo i found real cheap. only thing is ill need a hks adj actuator or ill need to ext waste gate my setup to max out the t25. ill let u know what works out for me, my motors alomst done bering rebuilt. cant wait to get it tuned again soonca18detgabby wrote:if you are looking for a curve like that.............
wouldnt uping the compression make sense?
if I really needed power that quick a little direct port setup would suit me........ but I happen to like the ability to drive out of boost on city streets......
I also wonder(probably get cracked on for saying it) but maybe running a SRT25 would make sense........ you seem to want the power ASAP, so running a turbo that is reasonably sized for a stock motor would make sense with all the extra mods you have. That +high compression I WOULD THINK........ would spool real quick.
yeah. i realize it takes a lot more but i don't have any personal experience so i guess i didn't realize exactly how much more. but it's still a good route to go =)r34 gtr wrote:Mmmmm E85.... I'd want some 750s for E85 though. You need to dump a fair bit more of that stuff in there.
Ryans setup is custom, no manufacture makes off the shelf high compression pistons for the CA, they have to make a one off.jrsink wrote:IS IT REAlly safe tho running a turbo on this motor with compression bumped up to like 10:1?
i had never really thought about that route. i will still be using my existing megasquirt to run the whole thing, although ive read alot about e85, im sticking with MS for now.i think im gonna go with the evo 560ccs for now, the price is great. havnt heard anything back from the shop rebuilding my motor yet, but id like to get some more info on upping compression.
I dont see why MS is discouraging you from using E85. MS is a complete standalone capable of using gasoline, alcohol. You can even get a flex fuel sensor and wire it to MS and it will automatically adjust your maps when it senses E85.
http://www.megamanual.com/flexfuel.htm
MS has nothing to do with running E85 or not........ Im not sure what it has to do with anything. If anything I would think MS would make it easier to run E85
so theoreticly he could go find a 50 dollar set of pistons from an old pulsar and run those instead........The_Chosen_One wrote:
IIRC DE pistons aren't as strong and some other doodads. So yea you could use them but it would be worth it, probably not.ca18detgabby wrote:
at 9.5 I would think an awesome tune might even be able to get away with big injectors and pump......... but idk.
Just run more boost
