WDRacing wrote:Do you want a NA engine or a boosted engine? Keep in mind you'll need an IC etc if its boosted. Might effect your dimensions a little.
WD
correct. i really dont mind if its boosted or na but i would like to reach 300whp either way. however piping is an issue to consider i dont look a lot into it seeing that piping shouldnt be hard to accomdate the setup.
redtop91 wrote:I'm sorry but this topic cannot be productive without at least a type of car you are looking at. Otherwise we could say any motor justifiably. Since we have no constraints I am going to go with 4G63.
y the need for a car? have u ever seen a kit car? some are made of just bars welded together. what manufacturer is that? i dont mean to be rude, especially since im asking for help finding a good engine but honestly it won't have an effect. the engine is going in the BACK. rear end will be COMPLETELY CUSTOM. no not just any motor because like i said in the beginning it needs to fit within particular dimension. ill explain again which dimension is the important one.
oh and ya the 4g63 is a good engine but if your talking awd transmission then where the front drive wheels used to be powered would be useless. unless you r talking the fwd transmission then that is possible as well too but im hoping to get engine more in front of rear wheels then on top.
i need the measurement from the crank pulley to the end of the transmission to be as short as possible. if its transverse mounted engine then i need the width of the engine to be short. make sense now? if u need i can do a long paragraph explaining what exactly i want and i can even include pics(not trying to be smart a$$ but i really can if u want) however i've been trying to keep it short while maintaining important info.
WDRacing wrote:If the LS1 will fit, use it. It's light and has been known to make 600whp with basic NA mods...
true but the transmission? did u check the link? if i want a transmission to handle that hp then i have to put like $9000 in transmission alone! unless u know of another company or transmission i can attach to it that will handle the torque?
the transmission length seems to be what gets in the way so far. any further help is greatly appreciated.
