Don't be so quick to down the 264s until you've tried them yourself. The hks 264s with the 8.5mm lift is the perfect cam for this motor when you're talking street/strip. The 272s will require extra machining and will choke-off some of your already weak low rpm power. It all depends on what you want. I have a set of regrinds in one my g/f's motor and I assure you it will out perform the 264s and the 256s and is also an awesome alternative to the 272s. Unfortunately, this grind is mine in particular and I asked for the specs specifically. So I say, select yor weapons carefully. Bigger doesn't always mean better, especially when it comes to the CA.c-rad wrote:256 AND 264's are weeeeeak. 272's all the way!
I was kidding... I was just referencing the lopey idle and V8 rumble they resemble...boost_boy wrote: Don't be so quick to down the 264s until you've tried them yourself. The hks 264s with the 8.5mm lift is the perfect cam for this motor when you're talking street/strip. The 272s will require extra machining and will choke-off some of your already weak low rpm power. It all depends on what you want. I have a set of regrinds in one my g/f's motor and I assure you it will out perform the 264s and the 256s and is also an awesome alternative to the 272s. Unfortunately, this grind is mine in particular and I asked for the specs specifically. So I say, select yor weapons carefully. Bigger doesn't always mean better, especially when it comes to the CA.
Dee
If you can find some stainless valves, let me know where and how much.DriftSpecial180 wrote:i was thinking about getting my head done, ported & polish w/ new valves and springs. I also wanted to get new cams. Boost_Boy, i like the torquey feeling, for drift a circuit racing. 256 the best choice?
Go with the 256s as they'll assist you inretaining the low end power you're looking for. Be sure that you request a decent lift on them if you order directly from one of the big dog companies in Japan.DriftSpecial180 wrote:i was thinking about getting my head done, ported & polish w/ new valves and springs. I also wanted to get new cams. Boost_Boy, i like the torquey feeling, for drift a circuit racing. 256 the best choice?
Why do you want to replace them? Are the pistons worn or the rods bent? If they are not, I highly recommend getting yourself some new rings, some new rod bearings, and if you really want to be safe, get the rods re-shotpeened. There's no need to spend oodles of money on rods and pistons unless you're going for the gusto.nismoser2002 wrote:what do you recommend as far as replacing the rods and pistons, and how much should i be lookin to spend on them also.
Thanks for the input, 256* on both sides? Or 256* in with stock exhaust? Can you share secrets?boost_boy wrote:Go with the 256s as they'll assist you inretaining the low end power you're looking for. Be sure that you request a decent lift on them if you order directly from one of the big dog companies in Japan.
Dee
Your question was a valid one. There haven't been too many threads on cam choices, and you seemed to know what you want as far as output and power levels. I wan't telling you to search at all... it was the kid who randomly posts "where can I get pistons and rods" in a thread about cams and headwork that pisses me off . Its not on topic to begin with, and its been thoroughly beaten to death in previous threads! I can't stand when people aren't willing to spend some time looking for the information on their own, and just want the guys who know what they're talking about to spoon feed them.DriftSpecial180 wrote:None had answered the question i had so i asked (which is the point of the forums).
I like this guy! He's a straight-up/tell-it-like-it-is enthusiast. I couldn't have put this one any better.NeedCAforS13 wrote:
And so you know, alot of us older guys like the fact that our forum is small... we know each other on a first name basis (most of us). I for one don't like the recent jump in people coming on here, asking "how do i make 500hp for cheap" then never posting again after we tell them how to do it and how much its going to cost. There's an aweful lot of 16 year old dreamers out there... and alot of them seem to like the CA for some reason.
If you (or anyone else) are serious about learning about this motor and getting power out of it, you will fit in well here Just remember it costs money to make power...
Sean
GoofyATX240, can you tell a big difference??? any power loss from down low???GoofyATX240 wrote:Im just running HKS 272's 8.5 mm lift.
I just re-read this statement, and thought I'd key you into a VERY important point... you say you looked over every thread in the CA forum that you could see by listing "view all threads" on the bottom of the page right? thats an EXTREMELY small selection of the entire threads in the CA forum archives, and actually contains very little useful information. Its just the last 13 pages of threads (last 3-4 months maybe), I would say there's another 100+ pages with thousands of threads in the archives, but you can only see them by SEARCHING. Don't be such a know-it-all especially if you're clueless as to what you're talking about. We have more than 13 pages of threads in our "dissapointingly small" forumDriftSpecial180 wrote:Your right, i didn't search...i looked over all the threads in this CA forum.
If you did a search in the archives you would have found theseDriftSpecial180 wrote:NeedCAforS13, Your right, i didn't search...i looked over all the threads in this CA forum. None had answered the question i had so i asked (which is the point of the forums). Just because you know the answers doesn't mean that we can't use the information. Besides this CA forum needs to grow. I've joined Zilvia, Club240, 240sxforums, FreshAlloy, and NissanForums to find info on the CA18. And do you know what all of them said? Go to NICO, the have a CA forum. So you guys that "own" the CA forum have quite the name to live up to (and i respect that) But It was dissappointing to see how small the CA forum was.
I'm not trying to trash this forum. Its small because the CA is a newly discovered gold mine for our cars. In a little bit of time, it will be huge.
