URAS »
https://forums.nicoclub.com/uras-u62334.html
Tue May 08, 2007 8:03 pm
Best setup
for Comps
Front 17x9" (we use RA-1 or R88 tyres)Total Toe out 5mmCastor 6.5-7 degreesCamber 3.2-3.4 degrees
Rear 18x9.5 (we use proxes 4 235/40/18)3mm total toe inTraction rod adjusted in 4mm0.5-1 degree camber depending on track.Pineapples set to maximum grip
For entry level drift ie non 4th gear speeds and second hand street tyres.
Total Toe out 2mmCastor 6.5-7 degreesCamber 2.5-2.7 degrees
0mm total toeTraction rod adjusted in 4mm1.2-1.5 degree camber depending on track.pineapples set to neutral
