kamikazi wrote:
toeyou can use toe to bit harder in turns but really eats up tires if using more than a couple digrees. .
also if you put about 2 deg. of toe in, in the rear of your buddies car it will kick out alot easier.
your explanation of camber was perfect, the most important thing to remember is since you are drifting its really easy to get an idea of how your camber is set because the tires wear so fast. you run a set of tires and look at the wear pattern, make adjustments off of that lol. just eyeballing it works great if its a serious track car.
but your toe explanation is 100% incorrect.
2 DEGREES of toe is INSANE. ive never seen that in my life on the most fully built cars on the planet. toe is measured in TENTHS of a degree or FRACTIONS of an inch. and toe OUT is for easy, snappy initiations. not toe IN.
here is a short explanation for REAR toe.
im gonna reiterate this is for the REAR of the car. not the front.
toe in - more traction, slower,harder initiations, more stable while drifting.
toe out - easier to initiate, easier to drift but not good for speed. (slower drifting compared to toe in)
for the first 2ish years i drifted i ran a little bit of toe out in the back (.1-.2degrees). it made initiating SUPER easy if you have some horsepower. i never had to clutch kick. just roll into the throttle and turn the wheel. even at 90 mph the back steps out nicely, even if its slower than a clutch kick. a couple months ago i made a change to toe IN in the rear because i was going for my "pro" license and needed some more traction and speed. it made a BIG difference in the way the car felt. I had to start clutch kicking and using more techniques to drift for the super high speed stuff but i also had to use less throttle adjustments to hold full lock and surprisingly less steering adjustments too. the car just has more traction while sideways. and i know that sounds stupid but if youve felt a change in handling like that you would understand. think of going from a ****ty all season tire to a Z speed high end tire.
