MrFox wrote:Totally daming the underbody airflow is not feasible or practical, so there'll still be lift. This lift will move rearward and increase in magnitude with speed. To maintain high speed stablitiy something like a wing or diffuser has to start forcing down in the back to balance out the lift.
this is correct, and is the only use of a wing on a fwd car. however a diffuser, or wing, used for moderate downforce could be much smaller, simpler, or OEM than "rice" wings.
Quote »The wing does helps high speed cornering grip by increasing downforce, but is somewhat detrimintal to overall cornering ability of the car by putting all that weight on top, increasing body roll and weight transfer.[/quote]
I dont think this is at all correct. The added (10lbs-20lbs) of a wing on the back of a car helps to place more weight over the back tires. (providing extra rear traction via weight transfer) At the same time it SHOULD be creating lbs in downforce, and have diffusers on each end, smooothing out the flow of air helping to counteract body roll. The additional weight transfer to the rear may be detrimental to FWD, but would definatly be useful in RWD cars.
Quote »If front wheel traction is a limiting factor for wing application in a FWD car, why not place the wing on or ahead the rear axle line. The downforce will no longer pivot on the rear wheels and try to lift the front, although it will not be as effective at pushing the tail down due to the reduced leverage arm it has on the rear wheels. [/quote]
as i agreed with your first statement, the limited use of a wing on a FWD would be to smooth airflow and provide extra rear wheel traction. (all to counteract lift) So now the back is planted. The front will still lift. Like i said in an earlier post, a good front bumber, chin spoiler and canards can be used to counteract this lift. not infinitely, and nto as well as a full wing, but that is the true function of an "aero package". As to putting the wing on the front of a car to counteract downforce, it isnt practical on street cars, but the F1 guys have been doing it for a long time.
