So your saying an engine makes more heat when theres a missfire then there is when your burning an air/fuel mixture? Im pretty your drastic heat rise is false, if anything it would be much cooler then what the cylinder sees during normal running operation.Kansei240sx wrote:Fuel cut is not safer than ignition cut.
Fuel cools the cylinders down at higher RPMs.
You're going to increase cylinder temperature at higher rpms drastically when you drop fuel for a few split seconds, causing damage over time.
If you cut ignition and fuel mist is injected into the cylinder a cylinder quench occurs dropping the temp of the combustion chamber and the unburnt and unvaporized air fuel mixture goes into the exhaust. Since the exhaust is so hot from an already running engine, the exhaust is the catalyst that re-ignites the fuel causing the loud popping or back-firing in the exhaust.
I dont know about you guys, but i'd rather have the engine dump a little bit of fuel for a higher RPM situation and worry about changing spark plugs occasionally from a rich condition than possible engine failure due than being into fuel cut threshold all day when drifting or on a circuit track.
If you ever get the chance, just watch a data log from AFR plots for comparing fuel cut to ignition cut and the difference is clear.
In my experience, Fuel cut < Ignition Cut
I have used the Bee-R before and had no problems with it, and THE worst thing i've seen it do is burn up glass packs, but thats about it.
Klodust wrote: Sound clip of tezuka's BNR32http://www.youtube.com/watch?v=IctMl9xM ... ?v...latedhttp://www.youtube.com/watch?v=O8wE8NTK ... ?v...latedi would love to hear this car in person
they dont call him "Shotgun" Tezuka for nothing.IMO: hearing "Shotguns" RB with the BEE*R bouncing off the rev-limiter shooting fireballs and shot gun sounds is like walking up to the pearly gates of heaven and having god look me in the face and say "You are my greatest creation... EVVUR!"or something like that...tctomasc wrote:those are some loud a** backfires
If you think a cylinder that isnt firing what so ever is hotter then a cylinder actually firing and makin an internal combustion (explosion) your a moron.Kansei240sx wrote:Yes, that is what i am saying, Gasoline is a lubricant and a coolant for the cylinders, the only thing it does when ignition cuts is take away ambient cylinder heat from the previous combustion just fractions of a second earlier, which is still enough to make a difference when you're in the red zone all day.
Thats pretty strait forward, unless you didnt misunderstood my point in the first place.Kansei240sx wrote:Yes, that is what i am saying, Gasoline is a lubricant and a coolant for the cylinders, the only thing it does when ignition cuts is take away ambient cylinder heat from the previous combustion just fractions of a second earlier, which is still enough to make a difference when you're in the red zone all day.
but can you see the point where the op said he doesnt wanna hear what the effects on his engine will be? so whats the purpose of sitting there arguing about something that doesnt even matter? someone got too much time on their hands?carkook wrote:
Overall, a fuel cutt does not result in a lean condition. A lean condition is when there is fuel and air being burned, but very little fuel. In a fuell cutt it completly cutts fuel and there is no combustion or firing of anything. There is no stress on the cylinder whatsoever because there is no explosion at all. So all this about it running lean when you hit a fuel cutt is false. Then arguing that a rich engine is better then lean has no point. Because my statements show that there is no lean condition.
Then your statement saying that fuel is going to cool the cylinder, obviously a cylinder that isnt firing(during a fuel cutt) is going to run much cooler then one firing in the first place so there is no harm in terms of heat. So thats pretty much bull.
So if your gonna sit here and try to explain why washing your rings with fuel is better then cutting fuel completly and having no rich or lean condition, your just wasting your time.
This is how it was explained to me by a mechanical engineer, you really think your explanations are more educated, and even I can see why the points you are trying to make are wrong
I was just trying educate people on what the fuel cutt really does. Everythong is stuck thinking its horrible for your engine. When really it has the advantages. So if you actually understood that the fuel cutt is actually better then an ignition cutt you wouldnt want to spend your money on something that really isnt necessary.jeff420 wrote:
It just turned into an argument because people no matter what think they are right even when they might have very little knowledge on the subject rather then try and understand what I am explaining and that they might actually be wrong. If you take the time and read what I have stated and what they have said, you can clearly see that every statement I make is backed by fact. But I guess some people think they are smarter then someone who was trusted to work on some of the biggest engines on marine ships in the navy, and with several years of expierence in the automotive field building engines.
Yeah, except it doesn't cut ignition when you shift.......... so you fail. And it's not a misfiring system. Where did you get this info from? I would like to read it myself honestly.TimTurboZ wrote:I can't believe the lack of research! You all FAIL! I was looking into the Bee R Limiter a while back. It's used to optimize power and keep your turbo spooling. It's a misfiring system (haha think Initial D) It cuts spark in a cylinder thus making fuel go into the exhaust during the exhaust stroke. The unburned fuel is then ignited by the heat of your header or exhaust manifold. This makes your turbo stay spooling. It helps keep boost up between shifts and I imagine spool quicker (forgot the exact detail I read) It's shortens the life of yout turbo because it's more wear on the seals. I don't think it would damage your motor. For an NA car it's only benefit is cool backfiring.
Your extremely ignorant. I actually feel dummer for having read this thread. You have taken this thread in the completely wrong direction just for your own sake of getting into an argument. You fail to see anyone elses logic in their arguments and just outright refute most information thats backed up, and this ***hole that you respond to is completely wrong and you say you agree. You are full of s*** GTFO .carkook wrote:Yeah, that makes since. I was just trying to get the point across that fuel cut does not make a LEAN condition. People just like to argue, including me haha.
