Will this work with the V-01 rears? Has anyone here done it?Black_Mx wrote:You might want to look into this.
http://www.infinitig37.com/infiniti-G35 ... coils.html
what he said06M4.5 wrote:front is too high
1 finger gap at all 4 corners would be great.
Ilyakol, Did you ever get this aligned yet? Any issues with the alignment? I'm thinking about D2 coilovers to get a small drop but don't want to go forward if alignment is going to be a problem for even a small drop. As far as I know the camber adjustment kits are not available for the awd...IlyaKol wrote:How fast do these settle? Cause it's a little lower now. lol.
I want at least a finger and half/two fingers cap all around. This is way too low for me.
How many miles are on your car? If it is anything over 60-70k, I probably would have done the struts/shocks at the same time.Twizz wrote:I have the Esplirs and you wouldn't be able to put a finger or 2 in the back. The front would might be able to get 2 fingers in. I left the stock struts tho... Do you think I should have (going forward) change them ?
Sure you can. Many people run springs instead of coilovers. Me personally, I don't really like to put springs on stock struts as the struts weren't made for lowering. But, with coilovers, everything is made to work together.lovemycarM35 wrote:Ok so all of this is confusing to me can't I just go with spring to get a small drop on my car? why coil overs
if your looking for a small drop H-Tech springs are the way to golovemycarM35 wrote:Ok so all of this is confusing to me can't I just go with spring to get a small drop on my car? why coil overs
