battery choice
ray666
Car: '92 240 sr powered tuned with a neo
I'm getting ready to swap and wanted to see if anyone had recommendations on a slim battery? i don't want to relocate.
J240sx
Car: 89 240sx
I believe the battery from a 93 miata will work..dbl check the year though.
vin diesel
Car: 99 328i
these are only 3 in. i saw a cobra with one today http://www.performancedistribu...s.htm
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
I ran a 91 Miata battery for 4 years. Fit perfectly in the spot, and as long as I didn't leave the headlights on overnight, it had plenty of punch.
It did not fare well over the winter though. It got wicked cold this year, and I think it may have gotten as low as 20 below inside my attached garage, because spring rolled around and she wouldn't even begin to hold a charge. I now run an Optima Redtop in the trunk.
S14toRPS13
I have a Bosch Mega Power 44B19R. Small, slim and works great. I didn't run my car for about 2 weeks and now it won't hold a charge though. Before that, I never had an issue with it.
ray666
all the batteries mentioned above are around the same size? i'm gonna be running 2.75"pipe . just want to make sure i have enough room.
J240sx
Car: 89 240sx
I think i am just going to follow Ian and just put an optima in the trunk. Not too much extra work to relocate it.
ray666
i don't mind running to the trunk but if i can keep from doing that, then why do it?
IanS
ray666 wrote:all the batteries mentioned above are around the same size? i'm gonna be running 2.75"pipe . just want to make sure i have enough room.
You should be fine, I have the old style Greddy VSPL, and the piping on the cold side is 2.5" IIRC. There should be enough room for a jump to 2.75.
ray666 wrote:i don't mind running to the trunk but if i can keep from doing that, then why do it?
Thats how I felt when I first swapped, but when it came time to get a new battery, (average life is 3-4 years MAX) I decided to clean up my engine bay a little. Optima batteries are head + shoulders above everything else, and they are sealed dry cell, so there is no need to run a box in the trunk. All you have to buy is a chunk of battery cable, a tie down, and a couple ends. I did the whole relocation for less than $200, including the $140 cost of the battery itself. I really liked the my engine bay is coming together, now that Ive removed and hidden all my accessory wiring. Now I just need to finish tucking all my vacuum lines, and removing the ABS.
ray666
I went to the local parts store...advance auto parts. they didn't have any optima batts. so i ordered a westco from frsport. the desc. said it would work. i guess i'll find out
cody180sx
Car: s14 rb25det fully built 550whp coming soon
+1 for the optima my car was down for most of the winter while i installed a new clutch sat up for 6 months, the day we went to start it no problems still holding 12-13 volts. If your worried about paying a lot for them go to your local interstate battery and pick up a BLEM nothing wrong with it just the case was scratched are something and they can't sell it as a new battery i payed 80 bucks after tax for mine and they normally go for 150 after taxes
exit7aracing
Car: 1989 240sx coupe
braille makes a great slim and light weight battery. an 11.5lb i had that one it was great and a 6.5lb. great reliable batterys even in winter
XSpower-Derek
Car: 98 ford explorer / 88 civic wagon 4wd / 2000 S-10 reg cab / soon to be 240...
ehh... not trying to plug my own company or anything but i would also like to throw in the XS power D/S 680 into the mix, its a solid design and its THE strongest battery availible in it's class
Sil80315
Car: 1991 Nissan 240sx
yeah im running a miata battery and I love it. Good deal for only 60 bucks from the dealer
