So I was reading this
corrosion-on-the-negative-battery-terminal-t516942.html
Someone said this
So I guess I should replace the damn thing! lol. What brand is reliable? or should I get an OEM battery?Even if you get brand new cables/terminals the problem will come back over and over because.........it is the fault of the battery in your car- what happens is the battery acid vents{as a gas} and seeps around the battery post where it exits the battery {due to a failed seal around the battery post} and builds up corrosion where the 2 metals meet { the battery post and the cable terminal}.
This happened to every single genuine Infiniti battery I ever had in the Q {4 of them if I recall correctly} I installed a AGM Odyssey battery 30 months ago and have never needed to clean the connection, it remains perfect - the AGM type batteries are not acid flooded like conventional batteries and this I believe made all the difference
The reason I ask is, every 2 few months, my battery would die out of the blue. I pop open the hood and see the acid build up on the negative wire. I wiggle the cable a bit, wait a few minutes and pray for it to turn on!
So yeah, what battery should I get my NICO friends?
