qship96 wrote:Even if you get brand new cables/terminals the problem will come back over and over because.........it is the fault of the battery in your car- what happens is the battery acid vents{as a gas} and seeps around the battery post where it exits the battery {due to a failed seal around the battery post} and builds up corrosion where the 2 metals meet { the battery post and the cable terminal}.
This happened to every single genuine Infiniti battery I ever had in the Q {4 of them if I recall correctly} I installed a AGM Odyssey battery 30 months ago and have never needed to clean the connection, it remains perfect - the AGM type batteries are not acid flooded like conventional batteries and this I believe made all the difference
This is a Costco battery and this is the second time this happened with this brand battery. The previous battery was a NTB (OEM on Infiniti's) and I never had any problems with it. But I got a Costco battery because of the warranty they gave with them. Costco does carry Optima brand batteries and I will go today to take a gander (Funny word, Gander) at them.
Q451990 wrote:Good to see you back on here!
I use the $1 treated anti-corrosion felt washers from Wal-Mart. Usually re-use them from battery to battery. I'd just clean it up and try that - I've never a problem with them.
Heath
I tired those And they did nothing for me.
djwarner wrote:There is also a red corrosion preventative spray that you apply after you clean away the corrosion and re-attached the negative lead. Simply spray the terminal to seal the metals from the acid rich atmosphere.
BTW the proper method of cleaning the green corrosion is to mix baking soda and water and apply with a throw away brush. After the corrosion melts away, rinse down the area let let dry.
I tried the spray and that also did nothing and the terminals were clean as can be, And I used 1000 Q-tips to clean the rear door checks, front air vents and more on my car.
