Baller on a budget: Carl H's RB30DET build!
Carl H
As most of you guys know I've been a long time rb20 fan...however several things have happened thus far to make me decide to ditch the trusty rb20 that has faithfuly served me for the past 6-7 years.
The 20 was loosing compression quickly and hadn't ever ran right since i rebuilt it; constantly ate oil and had pretty bad blowby from the begining...i think the machine shop set the rings up on the 'loose side' and it probably didnt help that I set up large injectors on a fresh block, live and learn.
I had intially thought about puting a VH45 into the s14 as i was very impressed with the engines capability in the s13 coupe i built around this time last year or so...however a good friend of mine talked me out of it and insisted i stay rb series and sudgested rb30.
I looked into it and found that the r32 rb25de head would allow me to bolt on all of my old rb20 go fast bits would bolt/drop into it without any modifications to the head which is great as buying new parts would have made the build VERY expensive.
This is not really a how to as if you're interested in it there is a HUGE (300+ page) thread on skylines australia and a few individuals have compressed all pertinent information down into a single pdf; go there to find it.
I have just finished running the engine in thru its intiall break in period, about 260mi on the engine now and it pulls great idle vac. and idles buttery smooth, its strong idle is very much like my jag's idle with only a 30rpm fluctuation.
Most of the fuel mapping is complete, just waiting to get some dyno time so I can dial in the ignition timing and make some real power!
Mod list for the engine:
r32 rb25de head - fully decarbonized and chem dipped, rebuilt to spec
holden/nissan rb30e s2 block - oil, coolant, and return lines already tapped
SPOOL imports external head drain
N1 oil pump
N1 water pump
RawBrokerage crank collar
Tomei oil restrictors (x2)
Tomei rb20 valve springs - off of my 20
Tomei pro cams 260/8.9mm - off of my 20
Ross metal jacket ballancer - off of my 20
Greddy cam gears (in/exh) - off of my 20
RIPS intake manifold - off of my 20
HKS exhaust manifold - - off of my 20
GT3076R converted to HKS 3037s spec w atp twin entry housing - off of my 20
Greddy 720cc injectors - off of my 20
Z32 maf - off of my 20
ARP exhaust manifold studs - off of my 20
ARP head studs
ARP rod bolts - use sr20 bolts!
OEM rings - you have no idea how hard these are to find!
ACL main/rod bearings - stocked stateside!
Lightweight flywheel
Spec z32 na stage 3+ clutch
new nissan wristpin snap rings
new nissan tensioner studs - a MUST, do not use old hardware unless you like snappage!
gates vw/audi timing belt p/n T291 - proper 152 tooth belt, gates makes good stuff.
new freeze plugs
And to the part everyone wants to see...pictures!
I came by the blocks from a fellow who was exporting them to the us, the same friend that talked me into the 30 also decided to build one since it would trump his rb26 build that he had in the works.
Engines after unwrapping and unstrapping:
first order of buisness was to tear down my block in order to prep it to be sent to the machine shop for a good hot tanking, hone and mods to the block for the secondary tensioner.
engines looked to be in good nic for the most part as they spun over smoothly with no binding but my block had signs of water sitting on the pistons for a bit, luckily it was mostly superficial and the hone cleaned it up.
Pistons however were gross, both engines had very dirty pistons with obvious signs of blowby...either a bad break in or just worn to hell rings it honestly looked like a combination of both.
Pistons and rods seperated, heat gun works wonders here!
Several soakings in carb dip over the course of a few days resulted in pistons that were almost brand new looking with minimal wear on the skirts, most of the blowby was superficial but it was very hard to disolve the varnish...a toothbrush and pipe cleaners was the only way to go here!
since i have little faith in nissan rod bolts being reused, yet alone unknown mileage as well as age it was deicided to fit arp rod bolts...however no one likes to give out info on what fits so i ended up buying several sets of rod bolts as my inital call to arp was about as much good as shouting at a brick wall...here is a shot of the big end of the rod with one rod bolt removed and a vg30e rod bolt next to it.
the vg30e rod bolt is much too short and does not have enough protrustion to locate the cap, do not use these.
the later vg30de bolts are too LONG and must be cut down to clear the crank, however cutting a bolt is not advised as it affects the fasteners overall clamping strength.
the bolts you want are off the shelf sr20 bolts, unfortunately this means you have to buy two packs of bolts...oh well, name of the game.
Bottom end assembly was done by myself and a friend, being the first time I've assembled a bottom end I made sure that we were very careful in assembly, all steps were performed as per the FSM; a learning experience to say the least.
All bearing surfaces were plastigauged and found to be within spec, if i continue assembling engines for myself and customers I plan on a proper mic set and bore gauge.
Main bearings laid in their respective grooves after cleaning the bearing surfaces and faces of any dust.
plastigauge on the crank, flash washed it out unfortunately.
Bottom end assembled with copious ammounts of assembly lube, too much is better than too little!
Block as it sits awaiting piston/rod assemblies:
front shot of the block showing the secondary tensioner relocation as well as mounted water and oil pumps
unfortunately I dont have any pictures of us fitting the rings to the pistons as just about everything was coated in oil (tools, block, hands) and I was unable to snap pictures of the procedure, but its really not hard...again paying attention to the fsm and the marking/direction of the rings all slid in smoothly.
ring gaps were checked but unfortunately no reference values were available, so we checked for uniformity and there was close to no discrenable variance in the ring gaps between cylinders; this block had the same grade pistons 1-6.
We did all assembly rings using 30wt non detergent oil to lube the bores up, wrist pins were slid in using 30wt and the rings lubricated with a quick shot of wd40.
piston/rod assemblies fully assembled, box was clean and free of dirt and grit.
close up of the installed rings, oil ring was the hardest to set up.
Overhead shot of the pistons installed in the block, torque specs were checked 3 times on mains and rods to ensure nothing was loose.
side shot of the assembled short block, notice brand new freeze plugs
Something I feel should be mentioned as its not well covered in the pdf on SAU nor on SAU's forums (as not many people have swapped 30s into s chassis cars)...the oil pan.
The rb30 oilpan fits in an s chassis car if you dont care about the front sway bar and remove it, thus you MUST use the skyline oilpan as it has a cutout for the sway bar to clear properly...dont ask me how i found this out but it was irritating to have the engine in car only to pull it.
if you have an EARLY rb20 then the pan will bolt right on no worries, however if you have a late rb20/ rb25 pan then the rear baffles must be removed to prevent crank fouling due to the longer stroke.
rb30 pan:
rb20/25 pan:
The r32 rb25de motorset was dirty, previous owner must not have cared for it much as the head was dirty and kinda sludgy...luckily everything from the head was removed and binned except the valves and was cleaned thoughorly.
Head was SPOTLESS after i got it back from my machinist and this is how the ports and combustion chambers looked:
One point of interest is the powersteering bracket, the rb30 has provisions for the ps pump bracket on the block unlike the 25/26/20 which bolts to the block and the head, to fix this the top lug must be ground down flush with the other mount points on the block.
The work is quickly accomplished with an angle grinder but you have to be careful and not remove too much material else it will not sit flush with the block!
Bolting the head onto the block is just like doing a head job on any other rb engine except the deck higth is a hair over an inch taller (around 38mm) so setting up the timing belt can be tricky, using the tooth count method to ensure the cams are set correctly is much perfered over the 'line the lines up' method as the gates timing belt does not have the proper marks to set timing...one must set the crank to tdc perfect via the mark on the crank timing sprocket and oil pump or with a degree wheel, both will work.
I found it helpful to mark the timing belt using the rb20's timing belt as it had marks for the cam gears with the proper tooth spacing on it, again check fsm for this info.
It should be noted that when doing any cam related work that an engine that has had either its head or block decked (or both) that adjustable timing gears should be installed and degreed to cam mfg. specs, there is lots of power to be had with correct cam timing and it saves the hassle of 'playing with the cams' on the dyno as more often than not the results found on the dyno are the correct values for properly degreed cams.
Companies dont put money into cam development without finding optimum values...best to roll with it!
FWIW my cams required .5* retard intake and 2* advance exhaust, your mileage may vary.
Timing belt run and...timed:
Exhaust manifold bolted in, do note that the water galley 'ridges' interfere with the exhaust manifold and both block and manifold require clearancing for proper fitment, this is best done before the block is machined as it creates alot of abrasive dust.
For anyone running an r series xmember you'll find that hood clearance goes out the window if you're using stock mounts, with the engine sitting on stock mounts it sat proud of the fenders by a good inch and change due to the increased deck hight.
Here are some pics of the engine sitting on the engine mounts and bolted to the crossmember.
This was rectified by making my own engine mounts out of some hockey pucks and plate steel i had left over from my vh project car, you have no idea how hard it is to find hockey pucks in the south...had to go to a skating rink to get these!
Mounts are a thru bolt design with bushings on the ends to prevent overstressing of the bolt and alow flex in the system, however these mounts are just about as solid as you get without using metal blocks!
the custom engine mounts along with a modified xmember (2 holes drilled) allowed for the engine to just barely squeeze under the hood, a very small portion of hood skeleton had to be trimmed but the liner was left uncut and is virtually undetectable.
For all intents and purposes it looks a whole lot like my orginal 20 setup as pictured as all plumbing was reused, only difference is the head sits taller and the valve cover breathers have been tapped and replaced with lower profile right angle hose barbs.
Driving this car is a totally different experience, turbo comes on full song (14psi) at 3krpm in 5th gear and response is AMAZING, boost is modulated by the gas pedal.
Power delivery is nice and smooth with excelent street manners, timing is set very conservative for the CR of the engine (approx 8.3:1) and I am just waiting for some dyno time to dial in the timing map...with any luck i'll see close to 400whp on 14ish psi of boost!
And thats all I have for now, I'll grab a pic of the engine mount in the am.
As always any questions, just ask!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Balling! Intake ports the same size on the 25DE vs the 20DET? did u just plug and play your old harness and install all the old sensors? Make some new vids damn it!.
bRadical
Car: maroon 95 240 RB inside (Eatn By The Dragon)
black 95 240 RB25inside (running by 11-18-10)
hot damn lookin nice Carl!!! ill give u a call this week i wanna check that out!
Sil240
Car: Nissan S13 "The One Cam Wonder"
Thats AWESOME!!!
Nice work!!!
+1 to the vids!!!
Are you gonna bring her out to the Tail of the Dragon meet/cruise?
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
What timing belt did you use? I couldnt find the one on SAU anywhere so i bought this:
1997-1999 Audi A4 Timing Belt - Dayco - PN: 95291.
It fit perfectly, although its god damned tight when tensioned right (all three marks lining up).
Did you modify your engine brackets at all? In my s13 I'm using R32 crossmember/E30 mounts which don't look much thicker than your hockey puck ones. I'm hoping with some hood shimming/trimming I'll get away without having to destroy my hood.
Also, where did you get your rings? The only place i could find the rings was in australia and the guy wanted an arm and a leg for them so i said f*** it and reused the old ones because I'm putting in forged everything this winter.
ST240
Yellow4g63 wrote:Balling! Intake ports the same size on the 25DE vs the 20DET? did u just plug and play your old harness and install all the old sensors? Make some new vids damn it!.
Intake ports on the 25DE are slightly larger than 20DET, but smaller than 25DET. And yes, all sensors swap over :) .
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
How much boost are you looking to run on the current turbo? cdorhout's 3076 choked on his RB25/30 at about 25 psi if I remember correctly.
Cjmartz2k
Car: Hunting for a '89 GTR now
Looks good man! Lets see some video's of you spoolin' that thing in 4th :mike
flatrate
Car: S14 kouki
Darius wrote:How much boost are you looking to run on the current turbo? cdorhout's 3076 choked on his RB25/30 at about 25 psi if I remember correctly.
Could you explain this more? what kinda power was it making?
Yellow4g63
how much porting would be needed to match the 20 to the 25de intake manifold gasket port size?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
you know I like ;)
meet07
Car: 89 180sx rb25det
Got any more rb30 blocks?? And how strong are the rb30 pistons and rings???
Jables
Car: 1995 RB26DET S14, 1991 RB25DET S13, 1992 S13 LS1 Coupe
Nice job Carl!!! Keep it up!!!!
Carl H
i used the gates T291 timing belt, its for the early audi/vw 1.8t engines with the 152 tooth count, they changed it mid year to a 153 tooth count and revised tensioner due to the belts jumping time...gotta love german engineering.
took forever to find what belts would fit but i eventually stumbled across a post on SAU describing several different belts and opted for the gates belt as it was available stateside and only 20$!
cant really give out much info on the rings as they are a bit of the diamond on the rough side, all i can say is that if you need a set i can source them out for about 120$ for the ring set.
the port differences between the rb25 and rb20 head are not too much different but enough to make porting the manifold questionable...it is a bout a 5mm difference in the ports but if the ports are enlarged on the manifold then there will be very little material for the gasket to seal.
ive opted to selling my manifold (tear) and just having a new one made...that way another rb20 owner can put it to good use and it wont be bastardized just for my application.
currently i am on gate boost (14psi) and will eventually dial the boost up to 20ish psi...it seems past 20psi the turbine simply cannot flow enough air for the engine.
i may look into bringing in another block to forge the bottom end but it seems that 500whp is quite doable on stock pistons and rods (assuming good tune)...however if i do bring in another block i may bring in several as well.
if you're interested (and serious) pm me about it and it can be discussed.
ST240
Brackets? Did you slot them? I think i'm going to take them to my machinist to put a 3/4" slot in there to lower the engine. Hopefully it doesnt f*** with the driveline too much.
Carl H
nope, brackets are standard r32 gear...the puck mounts were all i needed to drop the engine to clear with minimal driveline deflection.
Eikon
Car: 71 240z, 93 Supra TT
... and the legend continues! You rock Carl!
I'll definitely stay tuned to this build.
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
Awesome Carl. Way to be smart about it. Ill be watching this closely
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
looking good carl...i wish there was still a subscribe button... :tisk:
Gabes13
Car: rb20det s13
Carl H wrote: RawBrokerage crank collar
Can you explain this a little?
toadx8u
1993 240sx Vert DD
1996 240sx LSx 5.3L
2004 Honda RC51
whats to explain? RawBrokerage sells a crank collar to fix nissans mistake....a must for any build.... :whistle:
Gabes13
Car: rb20det s13
I understand that, but what exactly is "wrong" with the factory one that it's being replaced with this one? I hear crank collar this, crank collar that but never why or how it sucks.
EDIT: Never mind. I found an older post that coolwhip (Ricky?) explains why. Good stuff good stuff.
HIGHFIV5
Car: 1989 240SX
Wicked build. Definitely something i would love to do in the future!!!
I didnt see you mention what transmission youre using???
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Carl H wrote:i used the gates T291 timing belt, its for the early audi/vw 1.8t engines with the 152 tooth count, they changed it mid year to a 153 tooth count and revised tensioner due to the belts jumping time...gotta love german engineering.
Very cool bud! ...as for the 3076... what A/R are you running again? With a 3L you could could easily go with a larger A/R if you were set up for a 20 with the one you have now... should help your flow issue a bit, but really at 400whp with 3L... I'd start shopping for a 35R... :yesnod
leekim
Car: 1995 240sx
looks really good. cant wait to see vids
Carl H
small update:
well had a chance to dynotune the car and dial in my timing like i wanted to last week...
much thanks to tex @ BRE for talking nelson at intense motorsports for letting us use their dyno while BRE is sourcing a new dyno to replace the dyno dynamics they sold with the old shop.
All runs were done with the car fully warmed up and car pulled in 4th gear, cooldown between boost levels tuning was done to prevent heatsoak and let the motor rest for a bit.
dyno is a dynodynamics 2WD unit eddy current, so we were able to load up the car quite a bit...well ok we loaded the crap out of it.
FYI the nickname for the dyno is 'heart breaker' so the numbers look low...well they're just numbers.
Baseline run for the engine with my 'safe tune' was 214hp and 10.8:1 afrs, not knowing how much timing the car could handle it was kept conservative.
Boost levels are 14,18,22 and 26; ecu is tuned for 14-22psi and 26 was done on a modifed load scaling just for that run.
We've essentially maxed out the turbo around 22-23psi, as you can see we only gained about 17hp at 25psi.
I speculate that the turbine and the turbine housing are a restriction at that point, the turbine housing is the .78 ar ATP twin scroll vband housing.
The torque drop off becomes more and more evident with the increasing boost levels, however in car you dont seem to feel it as much...a larger turbine or just a bigger turbo would fix the problem.
Overall im very happy with the setup, jumping from 214hp to 282hp was just phenominal, engine responded very well to the fuel/timing tuning...now on the lookout for either an HX35 or a borg warner s300s :D
Also modified the front timing cover and made an extension for the timing belt so it would be fully covered...now only the keen of eyes can detect its an rb30!
as it sits now, breather hoses missing from picture.
i need to get some videos soon, however its super hard to drive and film lol.
rb25det250sx
Car: '96 Nissan 240SX RB25DET powered!!!
did you use your Rb20 head? or am i missing something?
Carl H
r32 rb25de head...rare as unicorn poop.
flatrate
Car: S14 kouki
i wonder if thats whats holding my car back... i have the same turbo, with a 1.06 divided housing and it seems to not really make that great of power... i made 412 at 20psi on a dynojet.... be interesting to see what happens when you upgrade...
Im surprized it didnt spool faster, i get about 17psi around 3800RPM maybe VCT helps with that?
thanks for sharing
Zacho2
Car: RB25 Nissan Laurel
^I made 430 on a dynojet at 18.5 psi with my 3076r .82 on an rb25 :confused:
and 465 on a 40/60mix of ms109 and 91pump at 19.8 psi
I tuned mine myself though.
