Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Wed Jan 05, 2011 9:17 am
no real updates as the car has pretty much been flawless since it went into the car and I tuned it.
its very reliable and is loads of fun to drive.
the only issue i have had thus far with it was an oil consumption issue which ended up being an oil feed line issue; pushfit line i used for the feed (to get it running) was not rated for the heat of the turbo side of the engine...so it actually melted and was shooting oil onto the turbo manifold.
once that was fixed oil consumption ceased and the engine has been running like a top since.
I would like to change out the rips plenum for a different one as the rb20 runners are a restriction in the intake track, the 5mm port size difference im sure is causing turbulence issues and thus power loss.
I would also like to swap out the hotside on the turbo for a larger twin entry housing, something like the .86 or the 1.02 offering that atp has...again in theory should yield more high rpm power as the 'small' .78ar housing on the engine currently chokes the engine out past 6.
mixeds14 - clutch is a spec stage 3+, rated for 585ft/lbs. No issues with clutch...lots of issues with wheel spin!
