Bad Rust/Good Rust..lol
Wan
What do you guys consider as bad rust damage? Any pics? I need some examples (pictures) to compare to a car to see how bad the car really is......I know some of you will say all rust is bad but lets face it....A good number of 240s have rust ..even if its only a little bit...I said "A good number" lol not "all"....thanx everyone
H8tred
As a scale, good rust would be light surface rust with little pitting. Bad would be completely rusted through.To compound the scale, it's ok it it's on a part that can easily be replaced. For example a door or deck lid. Inner wheel wells, rockers, floorboards and so forth are a pain in the *** to fix.
Vegascorbin
Car: 1990 240sx dirt track race car
All rust is "Bad". it means the metal has been exposed to the eliments ans chemical changes have taken place.
What you are really asking is what is repairable rust damage and what is not. If it is on a non-critical part or easily replaced part then it is not a major concern as long as you are willing to replace/repair.
Major rust on the frame or suspension etc shoud be avoided like the plague because thatis what it is, a plague.
There are people that will repair rust on the frame etc. Most won't. It all comes down to how much effort you are willing to put in to correct the damage.
H8tred
Vegascorbin wrote:All rust is "Bad". it means the metal has been exposed to the eliments ans chemical changes have taken place.
He denoted that he knows that, his question is best read as; "I'm not going to find a car without rust, so what kind of rust is easiest to repair."
Wan
lol thats true h8tred..any pics as examples? ty
Vegascorbin
H8tred wrote:He denoted that he knows that, his question is best read as; "I'm not going to find a car without rust, so what kind of rust is easiest to repair."
My bad. I ask forgivness
If it is to the point of leaving pits in the metal when the rust is removed then it is a job best done by an experianced person. If the rust has created holes compoleatly through the metal then move on to the next car UNLESS it is on a replaceable part such as a front fender etc.
I hope that is a better answer.
BMAR240SX
Car: 1993 Nissan 240S Coupe
Wan
that doesnt look good... ty for pics
low91240sx
Car: 1991 Nissan 240SX LE/2005 Nissan Altima
IMO any rust can be fixed within reason like stated above it has to do with how much time and effort you want to put into it I mean some things are just a lost cause and your better off finding something else but I enjoy a good project best of luck to you both
