codyace »
https://forums.nicoclub.com/codyace-u28194.html
Sat Aug 22, 2009 7:08 am
(easier for me to consolidate thoughts in a list)
1. Stock SR timing is 15 degrees, not 20
2. Do you have your gauge/fpr installed correctly? (Sounds simple, but happens).
Filter>gauge>Rail In>Rail Out>FPR>Return to tank
3. How do you know it's rich? Wideband or dyno?
4. You have NO vacuum leaks/pressure tested your setup?
Knock codes are a oddball stup, and IMO often caused by false knock to begin with.
