Bad idling issues, need help please!
calazon
Car: 1990 Nissan 240sx
Hi, I just finished my SR swap a couple weeks ago, and since then have been having some issues with idling.
When I start the engine or stop after driving, it will go from about 2,000 down to almost stall, and pulse back and forth contuniously. It drives and runs fine otherwise. When I come to a stop it will stall if I don`t give it a little gas. I have ajusted the TPS to factory settings, gapped the plugs to where it doesn`t misfire, and adjusted the timing to where it runs smooth.
It is very anoying, and when I`m in town at a top light I feel like a douche because people think that I`m reving my engine contunuously haha...
Can anyone help me out with how I might fix this?
Thanks!
Modified by calazon at 2:54 PM 6/8/2008
240dk
Car: 92 Nissan 240sx SR
What kind of blow off valve do you have? If you have an atmospheric one it will cause problems like that, especially if it is leaking. I had the same problem and found out my bov was leaking so i replaced it and it doesnt do that anymore.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Do you have any ECU codes?
Just adjusting the timing till it sounds right is not good enough. You need to get a timing light and adjust the timing correctly, improper timing can cause all sorts of issues.
calazon
I have the stock blow off valve. It may actually be leaking... I had a suspicion that I could hear it leaking after boost but thought I was crazy.
No I don't have any ECU codes. The ECU I have is one I ordered that had been chipped/remapped/flashed whatever.
