bad 10-0 vac stutter ae86 ca18det
LandrethRacing185
Car: 1986 Corolla ae86
Ca18det powered
This is my first post on here
Ive got a 86 ae86 with a ca18det in it
did alittle searching and didnt really see any fixes just some old dead threads
CA has
t28
fmic
440 or 444 cc injectors
ka throttle body
butterflys removed
ebay exhaut mani
custom exhaust
z32 maf blow threw
1.3 head gasket
arp head studs
Exhaust cam on intake
currently 6psi till i get a good boost contorller
Unknown chip previous owner said had stage 3 chip
has a mad stutter from 10-0 vaccum
stutters worse cold then gets alittle better a it warms up but never goes away
and really rich close to wot
unsure codes yet going to check them this weekend
anyboyd ran into this problem lately
thanks for any infomation
float_6969
Sounds like a vac/boost leak. Always start with the codes first though.
LandrethRacing185
Ca18det powered
Did code check
Code 13 coolnt temp
Checked it .. Unplugged
So plugged it back in but haven't ran it to see if the stutter there or not
And how do u post pics and vids on this site?
LandrethRacing185
Ca18det powered
Update
Plugged coolant temp back in
Cleaned plugs
Fired up ran good I was like hell yea
Drove to car wash
Drove to local advance auto
Took it to my shop
Ran good
Fired up at night ...
Drove to my apartment
Idle misfire
Crusing misfire
Checked codes again
Code 13
What do u guys think ?!?!?!???
float_6969
posting pictures
how-to-post-pictures-using-photobucket-t521110.html
Vids is similar, you just use youtube and use the "youtube" tags on the link. If you use the full editor, it makes things easier.
See if the plug came off again. If it did, you're missing the little metal clip that holds the plug on the sensor. If it didn't, then you have a bad sensor or wiring between the ECU and the sensor.
LandrethRacing185
Ca18det powered
Ok thanks on the posting pics
It still plugged in so I think I got a bad sensor it runs good cold and gets worse the hotter it gets
LandrethRacing185
Ca18det powered
More info
fixed some leaks
put new coolant temp sensor
adjusted tps and cas
new bcpr6es-11 plugs gapped to .7 mm
idles great neutral rev great
driving under full throttle 3-4k stutters and misfires then clears up to 5k and misses and dont rev no more
drive 1/4 throttle no misses
i forgot to metion im using a f150 frame mount fuel pump for a v8 would that not flow enough for full throttlw but i havent had a problem with it up till now?
thanks
float_6969
Do you have a wideband? Can you see what the AFR's are like when it breaks up? It sounds like an ignition problem to me, but it could be leaning out as well.
LandrethRacing185
Ca18det powered
I don't have a wide band I need to get one
But after It did that I put a diffrent fpr on .. No difference and 1-4 plugs looked rich but 2-3 was white as all get out
I was reading up on boost cut or fuel cut
But I'm only running 6 psi according to my boost gauge
float_6969
Sounds like plugs 2&3 aren't firing or those injectors are bad. Clean all grounds. If problem persists, replace the plugs and move the coils to different cylinders. Ruin the engine for a bit then check the plugs again. If the white plugs follows the coils, replace coils, if they stay on 2&3 then it's the injectors or the ignition amplifier. Due to the behavior you're describing, I would suspect the ignition amplifier
LandrethRacing185
Ca18det powered
Another update
Changed maf no change
Ran another ground no change
Took ecu apart and has a Horsham stage 3 chip
With the 2-3 plugs being white wouldn't that mean that the 2-3 injectors are spraying making a lean mixture
If 2-3 lost spark wouldn't the plugs be black /suty and wet??
float_6969
A failed spark causes no combustion, which doesn't cause sooting. That leaves the plugs unchanged. They wouldn't be wet because the issue only occurs in boost
That Horsham chip is for a Z32 MAFS and 440cc injectors, plus intake, 3" turbo back, FMIC, and a T28 @ 17psi. Is that your setup?
LandrethRacing185
Ca18det powered
Thanks for the help I've got a drift event Sunday I gotta make it to so I'm in a frantic rush
I've got
Z32
440s
Fmic
Blow through
Custom 2in down pipe with 3 inch down back exhaust due to limited space in the ae
T28bb
The only thing I see is that I'm not running 17psi
And they say 97 oct in running 89
Could the fuel be a problem and the 17 psi
But I been running everything the same for about a year until I put this exhaust on then the problem occurred unsure if that's my problem or just a fluke
float_6969
Ignore the 97 octane. They use the RON octane rating there while we use the AKI, which yields a lower number. It's not a direct comparison, but 97 octane is ABOUT 93 octane here. 89 octane is too low and you're risking engine damage. 91 octane is probably fine if you're running lower boost levels. Running less boost than the chip is tuned for doesn't cause any issues, you just make less power.
LandrethRacing185
Ca18det powered
Ok thanks
I ordered up a inline walbro 255 pump
Doing some looking and my pump in running only does 100-120lph so I think that's my under fueling problem
LandrethRacing185
Ca18det powered
Put new pump in Saturday with no improvements
Took shot in dark and got a Ka alternator and made a bracket and that fixed my stutter
I'm guessing the alternator wasn't putting out enough anymore so I drifted all day Sunday and no problems
Thanks for the help
float_6969
That's a weird one! Glad you got it figured out!
LandrethRacing185
Ca18det powered
Thanks yeah I took the old one to advance and the machine said low output like 12.8 so with my fans and fuel pump running I bet that had it all messed up but
Now we know to double check voltage lol
dash
Car: s13 ca18
good of you to post the fix
so you have a 2" section in your downpipe ?
what fuel and how much boost you running ? ....and how does the car perform ?
LandrethRacing185
Ca18det powered
Yeah I have a
2inch down due to limited space currently
Then to a 3 in all the way back
Currwntly running 93 on 7 psi
Runs great alittle rich all the way through the rev range but I think that bc I'm running low boost
float_6969
All chip tunes are going to be rich. They still are less rich than stock and make more power than stock.
LandrethRacing185
Ca18det powered
Side note float
I'm looking for a ca18 power steering system
Brackets or pumps or something
I'm planning on doing 240sx front subframe and suspension so I wanna runn ps
