Exactly. I have my memory set to show all the way down and in so I can see my rims to curb. I don't want curb rash and I don't want tickets. But besides that, like Six-Legs said, I don't want to search for that switch every time for left and right...especially at night. So yes the side would go down according to which signal is engaged when in reverse.Six_Legs wrote:mostly to prevent any curb shots.
You guys signal when going in reverse?TDot wrote:Exactly. I have my memory set to show all the way down and in so I can see my rims to curb. I don't want curb rash and I don't want tickets. But besides that, like Six-Legs said, I don't want to search for that switch every time for left and right...especially at night. So yes the side would go down according to which signal is engaged when in reverse.Six_Legs wrote:mostly to prevent any curb shots.
I learned to drive in NYS, and was taught not to use the signal for parallel parking (MANY years ago). The current driver's manual for NYS says to use your signal when parking.IlyaKol wrote:He's saying he would, not that he does.svard75 wrote:
Wait ... what... really??? nicepegasus wrote:Mine actually malfunctioned for several days once, and both mirrors pointed down while in reverse. That was sweet...
Yea, and the selector was actually in the middle neutral position. That was nice, it should be like that full time.cruzad3r wrote:Wait ... what... really??? nicepegasus wrote:Mine actually malfunctioned for several days once, and both mirrors pointed down while in reverse. That was sweet...
Clearly I was too slow on programming. Unfortunately, I can't help you on reading the FSM, but see BCS-3 and BCS-4 for more clarity regarding my previous posts.TDot wrote:Correction,
1/ the terminal switches are 2 and 18 from the mirror remote.
2/ I believe it has to be 0V in order to activate each mirror and 5V to keep it stationary. Can someone confirm I'm Reading that right on GW fsm pg 93.
3/ also I figured how to make sure I keep it programmable the stock way. Just splice into the two wires with a wire tap instead of bypassing them. Then just keep the switch neutral during normal operations while I use the turn signal, and use the switch during programming and leave the turn signal alone.
I have a suggestion that might work, but would involve you pushing a button. Set your #1 memory to normal driving, set your #2 memory to be the same but with both mirrors dipped down to the curb. When you want to back up, push #2 and let the magic happen. Seems like the least intrusive way to achieve dual-dip... unless in the bold part of your post above, you meant you are already doing thisTDot wrote:Exactly. I have my memory set to show all the way down and in so I can see my rims to curb. I don't want curb rash and I don't want tickets. But besides that, like Six-Legs said, I don't want to search for that switch every time for left and right...especially at night. So yes the side would go down according to which signal is engaged when in reverse.Six_Legs wrote:mostly to prevent any curb shots.
Doesn't the car have to be in Park for memory buttons to move anything for some stupid reason? I know they won't work while the car is moving, but obviously you stop to parallel park. However, putting the car in park and hitting a button before putting it in reverse sounds like a PITA to me. Granted, it wouldn't require actual modification, but it also probably isn't much easier to "find" those buttons than the mirror L/R selector switch.EdBwoy wrote:I have a suggestion that might work, but would involve you pushing a button. Set your #1 memory to normal driving, set your #2 memory to be the same but with both mirrors dipped down to the curb. When you want to back up, push #2 and let the magic happen. Seems like the least intrusive way to achieve dual-dip... unless in the bold part of your post above, you meant you are already doing this
TDot, you need to start sleeping in or something. I'm supposed to be able to take my sweet time posting and not get pre-empted, but apparently not in this thread... Sheesh.TDot wrote:Plus, don't you have to put the car in park and press the button, and keep it in park until things get to position? Or is that just for the seats?
From the second chart and scanning through BCS-8, it looks to me like tapping into the MFS line that goes to the BCM inputs that trigger the turn signals would net the following:BCM reads information of a maximum of 20 switches by combining five output terminals (OUTPUT 1-5) and five input terminals (INPUT 1-5)
