Tulsa_S-13 wrote:First things that come to mind:
1. Are you running an atmospheric BOV? If so, because what was once metered air is now leaving the intake tract, the A/F go rather rich at deacceleration.
2. Are you still using the vehicles catalytic converter? Usually running a test pipe can cause unburnt fuel to ignite.
Be sure to check timing, as this can also be suspect to backfiring.
actually I have only heard it do this like once. I know I need another cat back system but I do not like loud. I am at stock boost levels right now so it should be good until I can afford a cat system -- are high flow cat coverters worth it or should you run a test pipe or stocker cat?nzmoman wrote:with that exhaust setup you are definitely fighting back pressure.
This is going to cause the noises even more if it is the fuel igniting in the exhaust. You dont have flow so your downpipe is just holding hot air and at a higher pressure. Throw another piston and keep it running and you will have a 5th cylinder.
that was a joke!
