Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Fri Jul 27, 2007 5:08 pm
the ss lines are nothing special, just lines done up at a local hydraulic shop, cost me 50$ for the 2 coolant lines and the oil feed.this is much cheaper and much more effective than pushfit, before i spent almost 250$ on line and fittings for the coolant lines and oil feed; boo to that.ive found that pushfit line is not good for this application; when i pulled my oil supply line off and tried to remove the clamp the hose had become so brittle from the heat that it literaly snapped in half, i was lucky that i wasnt driving when that happened.as far as mods go its pretty much got a new gt30r strapped to the side with the atp twin entry housing, on the hks manifold this should reduce spool time and give the car a bit more response.motor is currently in the car and i BARELY have enough clearance for the dp any luck and no rain i'll be able to get the dp fabbed up tommorow as well as the wg recirc.
