B16 Shopping List/Info on Parts Available
nametakennow
Car: '06 MINI Cooper S
I honestly don't know how similar the transmissions are. Isn't the 2.0 only 5 speeds though?
Contact the parts makers directly for a better response.
Added the TWM to the list.
about3blank
Car: 2007 Sentra 2.0
nametakennow wrote:I honestly don't know how similar the transmissions are. Isn't the 2.0 only 5 speeds though?
surprisingly enough, nope. it's a six-speed! on a 2.0! haha. i laughed when i first heard that too, but i love it now. saves on gas.
DarkAquarius
Car: 2010 NISSAN Sentra 2.0SR
Just as an FYI, Weapon-R has intakes for the 2.0 model for just under $200 at some online retail stores. This is the link the the Weapon-R website:http://weapon-r.com/english/in...=6254
nametakennow
Added the Weapon R.
Thanks for the contributions, guys! That's what makes this sort of list work.
08sentra2.0sl
Car: 08 Sentra 2.0 SL
Hey saw a fujita cai for 2.0 sentra, any comments on it? like it?
and what about the weapon intake? notice a difference in HP or TQ?
Thanks
DarkAquarius
FYI, Stillen has post a preformace lightweight pulleys for the 2.5 sentras. this is the link.http://www.stillen.com/product...ENTRAThey also added another lowering suspension kit from a german company called H&R. they claim it lower the car 1.5" front and back.http://www.stillen.com/product...ENTRA
nametakennow
Added.
H&R is actually a huge name. They're not as common, at least for Japanese vehicles, as Eibach or others, but they're definitely quality products. Looks like it's for 2.0 and 2.5's. Not surprising since the suspensions are the same, so technically you could use any SE-R suspension part on an S, SL, etc.
Psycosisnine
Car: 2008 Nissan Sentra SE-R Spec V
Nismo now has Cold air intake Cat back exhaust system Headers with and without catalytic converter and a bunch more
Here is the link http://www.thenissanpartsstore...Id=23
And this is my first post !
nametakennow
That looks like a link to the B15 (previous generation) NISMO parts, or is the picture up top of that page just not related to the parts? I hadn't heard anything about NISMO releasing 07+ parts yet...
JKing1589
Car: 2007 Sentra SE-R Spec V
Quote »Turbo KitTurbonetics (Under development, will be similar to 04-06 SE-R kit)[/quote]Still no turbo
Has anybody heard of anything about it...if there is gunna be one or when its gunna come out?
uprev
We're actively looking for Sentra Owners in the central Texas area to come buy and let us do some ECU work. First we'll need to get some of the ROMs fromt he ECU, once we have them patched we can work on getting the tuning software going.
We should be able to have it ready for our Pro Tuners in a very short time if we have some cars made available.
Also sort of curious as to forcing the CVT into a steady state for tuning, and what kind of reliability there will be with them. If any of the Nissan techs want to step forward and offer some guidance on the CVT setups, it would be greatly appreciated not only by us but by all the owners of cars with them.
ABNRML4U
Car: Nissan B13
Go with Meagan Racing Coilovers there Ajustable and have GREAT! ratings man! forget about springs .
bigbpatel
Car: 2009 nissan sentra 2.0L
hey are there any 2.0L cold air intakes out yet??
bigbpatel
yo would u recomend the fujita cold air intake? or the stillens?
nametakennow
Either. They offer similar performance.
bakerboard
Car: 2007 Nissan Sentra S 2.0
Hey just bumping this thread. Any new parts to add for the b17s?? and what about that turbo any kits out yet?
soulever989
Car: 2010 Sentra 2.0s
May be a stupid question, but can you just add a cat-back exhaust without having to tweak anything else on a 2.0L B16?
Also, I just got my 2010 sentra. Does Stillen's cat-back fit?
nametakennow
Catbacks are bolt-on. No other mods required.
djtorello
Car: 2008 nissan Sentra SE-r
Ive found Caliper upgrades for the 2.0L, which is the same for the SE-R, but not spec v, Not sure how acurrate this is though, never seen this listing before.
BTW, i cant direct link to the page, so go to http://www.nopi.com -> then Online store -> then Nissan -> Then Normal Sentra -> 2008 -> then Brake kit-performance. Enjoy
Rotora brand Special order - High Performance Brake System - RED Calipers with Cross-Drilled & Slotted RotorsEngine: 2.0L - Chassis: B16UFRONT - Caliper: 4 Piston - Rotor Size: 330mm x 30mm - Rotor Type: 2-PIECE - Wheel Clearance: (see image 2) A-30mm B-187mm C-113mm - SPECIAL ORDER ONLY (Lead time: 60-90 days)Mfg# RBK249.02-AC, NOPI# 064+5284Made of billet aluminum alloy and CNC-machined to ensure the highest quality, Rotora's High Performance Brake Systems, available in 6-Piston, 4-Piston & 2-Piston Calipers, enable superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias, Rotora's opposing piston calipers are fine tuned by increasing the clamp load to the optimal level while utilizng the stock master cylinder to retain overall front-to-rear brake bias. Rotora's full big brake system design delivers excellent initial bit, exceptional modulation and consistent pedal feel for street and track use applications. All systems are ABS compatible, direct bolt on and include DOT-compliant steel braided brake lines and carbon steel (SC45) mounting brackets and hardware with minimal modifications required. COMPONENTS/FEATURES: •Rotora billet aluminum alloy racing calipers with sequentially-sized piston bore sizes engineered to each specific vehicle. •Rotora billet aluminum hat with “floating” disc assembly to reduce heat-related stress and unsprung weight. •Rotora two-piece heat-treated directional vane disc system to improve airflow/cooling under severe braking. Slotted or drilled & slotted oversize 15” or 16” discs to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris. •Rotora ceramic-formulated brake pads designed for extreme street and off-road applications with high co-efficient of friction and high temperature fade resistance. •Rotora DOT-compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion. •Rotora SC45 carbon steel mounting brackets and hardware. - Additional Caliper Colors are available. Contact NOPI for info.
Mfg# RBK249.02-MS, NOPI# 064+5287Mfg# RBK249.02-MC, NOPI# 064+5286Mfg# RBK249.02-AC, NOPI# 064+5284Mfg# RBK249.02-AS, NOPI# 064+5285
Edit:
Same instruction to fint them, just Replace Normal Sentra, with Sentra SE-R
Just found the 2.5L Spec V listing:Mfg# RBK249.01-MC, NOPI# 064+5282 FrontMfg# RBK265.01-MC, NOPI# 064+5366 RearMfg# RBK249.01-MS, NOPI# 064+5283Mfg# RBK265.01-MS, NOPI# 064+5367Mfg# RBK249.01-AC, NOPI# 064+5280Mfg# RBK265.01-AC, NOPI# 064+5364Mfg# RBK249.01-AS, NOPI# 064+5281Mfg# RBK265.01-AS, NOPI# 064+5365
Other then color, the first 4 are blue, and the last 4 are red, and front and rear of each, those with MC and AC are Cross Drilled and slotted rotors, Those with MS and AS are just slotted rotors.
Goodridge SSBLStainless Steel Brake Line Kit - Rear Drum - Number of lines: 4Mfg# 22128, NOPI# 498+1601
Stainless Steel Brake Line Kit - SE-R Spec-V - Number of lines: 4Mfg# 22129, NOPI# 498+1602
More brake options found.....
http://www.streetbeatcustoms.com/2008/N ... rake-Kits/
Ksport Procomp Front Big Brake KitSBC-588426Listing Price: $2300.99Selling Price: $1868.99
AP Racing Big Brake KitSBC-589282Listing Price: $1438.99Selling Price: $1198.99
Springs:
Eibach Spec VPro-Kit Part # 6387.140Drop: 1.5"F/1.0"RSportline Part # 4.8763Drop: 2.0"F/1.5"REibach 2.0Pro-Kit Part # 6380.140Drop: 1.3"F/1.3"RSportline Part # 4.8063Drop: 1.7"F/1.7"RTanabe GF210Part # TGF134Drop: 0.8"F/1.0"RTanabe DF210Part # TDF134Drop: 1.5"F/1.6"RIntrax Spec V<<<Put in Sentra 2.5Part # 60.1.087Drop: 2.0"F/1.7"RIntrax 2.0<<<Put in Sentra B61Part # 60.1.081Drop: 1.7"F/1.7"RH&R Sport SpringPart # 53039Drop: 1.5"F/1.4"RKsport GT LoweringPart # LSNS29Drop: 1.2"F/1.2"R
Coilovers:
Megan RacingPart # MR-CDK-NS07K SportPart # CNS290-KPD2 Racing <<<Click on View ApplicationsPart # D2-N010-1
There are 2 choices for Carbon fibre hoods. Both are VIS.I cant C&P from their site....
Full Body Kit:AIT Racing
Lips:Stillen Front 2.0 and Spec V 2.0 Part # 108061 / 2.5 Part # 108114Stillen Rear 2.0 Only
Roof Wing:Stillen All Models
Rear Wing:Stillen 2.0 Only
Eye Lids:Fibre Customs
Hoods:VIS OEMVIS TERMINATOR
Mishimoto 08+ Nissan Sentra Vspec Manual Aluminum Radiator[MMRAD-SEN-08] MSRP: $340.00 Our Price: $253.99 You Save (Off MSRP): $86.01 (25%)
The Mishimoto performance aluminum radiator for the 2008+ Nissan Sentra Spec-V is designed and engineered to maximize cooling efficiency by up to 30%, boost engine functions, and protect your car from overheating. The Mishimoto 08+ Sentra Spec-V performance radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks, enhancing the overall performance of your engine. Every Mishimoto aluminum radiator is a direct OEM fit, making installation effortless. All Mishimoto radiators come with a high pressure 1.3 bar Mishimoto Radiator Cap and an excellent warranty.
This product was added to our catalog on Wednesday 04 November, 2009.
And 5zigen makes us a Catback, can be found on streetbeatcustoms,
Catback exhuast: SBC-1913
And you people tell me nothing is made for our cars. I walk away shaking my head.
nametakennow
Thanks for the additions.
sentrastace
Car: 2007 Nissan Sentra 2.0S
STILL nothing else good I can add to my b16.
djtorello
i
sentrastace wrote:STILL nothing else good I can add to my b16.
if your looking for just basic visuals, then no, nothing else, Performance however, there is quite a bit. This is only a small listing of the B16 parts list. I could add everything, but i think it will take about 9hrs to post.
Maybe someone other then me should do a bit of foot work. The main problem is, there are a huge listing of B16 parts, just that no 1 site lists them or sells them. So they are a bit harder to find.
Do you want Carbon Fibre Door sills? Nissan themselves sells them.http://www.courtesyparts.com/i...R.jpgManufacturer: Genuine Nissan Accessories Category: Interior Product SKU: 999G6-B16CR
Or should i add white face gauges to the list.....http://www.whitegauges.net/pro....html2007-2009 Nissan Sentra White Face GaugesRRP:$34.99Your Price:$19.99 (excluding tax) (You save $15.00)SKU:0709NS-1466
unmei
if you're serious about putting some sort of boost, you're gonna want to upgrade your front brakes as well as a rear drum-to-disc conversion, and there's brakes a-plenty. i'm personally a bit disappointed at the choice of intakes, but that's number 3 or 4 on my list of what to get with my tax refund
djtorello
Choice of intakes is a problem?
What brand are you specificly looking for?
on the 2.0L:
FujitaWeapon RInjenK&NBomezCosmoWhiteline
on the 2.5L:(Word of advice, the SE-R intakes are DIFFERENT then the SpecV)InjenK&NWeapon R
wingedmark
Car: 2007 nissan sentra 2.0s
does anyone know if they make a drum to disk brake conversion for the 07 2.0 cvt?
aebstract
Car: 09 Sentra SE-R Spec V
djtorello wrote:Choice of intakes is a problem?
on the 2.0L:
I think weapon R and K&N make a short ram, correct? Is there an actual CAI for the spec v yet or am I going to have to make my own? I was looking around and couldn't really find the information. I thought Injen had one but I don't see it for the spec v?
djtorello
Injen does make a SpecV intake as well as the SE-R.
I know for sure, cuase i got my injen second hand, it was for the SpecV, not the SE-R, and i had to do significant modification to make it fit.
Injen for SE-R Part Numbers: SP1963P (Polished) / SP1963BLK (Black)
Injen for Spec V Part Numbers: SP1968P (Polished) / SP1968BLK (Black)
There is a difference for SE-R and the Spec V on the Injens...
Weapon R SRI (All models)Part Number: 304-134-101
K&N Drop in Filter Spec VPart Number: 33-2409
K&N Typhoon Intake Spec VPart Number: 69-7001TTK
K&N Drop in Filter 2.0Part Number:33-2376
Fujita CAI 2.0 onlyPart Number: CA-2830
Bomz SRI 2.5LPart Number: NS0709AF
djtorello
wingedmark wrote:does anyone know if they make a drum to disk brake conversion for the 07 2.0 cvt?
There are a few available options, You can grab the parts for the SE-R or SpecV from a junk yard, or craigs list or ebay. Same parts from the Altima as well. $400 +
You can do the Dodge neon rear disc brake swap. $400-$800
Or you can do a Big Brake Upgrade, where as most companies convert the rear drums to disk anyway. $1500 +
unmei
on the 2.0L:
i haven't found an injen or k&n for the 2.0, and those are really what i want. everybody's got the weapon r, and i don't want to follow the bandwagon. what site did you see them at?
latunza
Hey dumb question but the spec v stillen lip kit can i put it on a 2007 2.0 S
