seang »
https://forums.nicoclub.com/seang-u122444.html
Mon May 10, 2010 10:54 pm
Then you would have the shifter and the ability to run 2wd if you wanted, something other AWD cars cannot do. I know the transfer is shift on the fly between 2hi and 4hi (it clicks in and out with ease even at speed as long as the hubs are locked); but that is with a 50/50 split, I'm not sure if that feature would be affected by the viscous coupler or not.
D21 does have equal length CV axles, which is good. I think there are steering dampeners available, too, to help with any possible torque steer. Not sure how much there would even be, honestly. I saw a video of a turbo Silverado launching in 4wd, and there was some torque steer for him.
Also, I have never heard of a D21 transfer case breaking. The stock 5sp (4wd version of the FS5W71C) on the other hand, is more likely to break if you thrash it. 240sx's and 2wd D21's and Frontiers also have this model, but I don't see fail stories like I have with the 4wd. I do know for sure that the 4wd 5sp transmissions have an oil fill plug that is an inch too low from the factory, and needs to be overfilled to avoid starving critical bearings of oil. 2wd and 240sx versions do not have this problem.
So that coupler would go with the front driveshaft? Are they reliable pieces?
[edited for info, see post below]
seang on Tue May 11, 2010 10:04 am, edited 1 time in total.
