nightfawl wrote:My wife primarily drives this vehicle and she is very light on the gas peddle. And I also looked at how many Km we are getting per tank and it is around 400km range when it's almost empty. Again that is city driving with quite a bit of stop and go in the city, but I still thought we should get better mileage. Would it be a waste of my time to bring it into Nissan to have them take a look?
I wouldn't hesitate to bring it to the dealer and mention the horrible gas mileage you're getting - mileage will be highly variable but if you are consistently only getting 400 km from a tank you are not even close, I get 550 km in winter with 100% city driving with my FWD 08 Rogue.
They can connect their diagnostic CONSULT tool to your car and check all of the sensor readings including combustion parameters, intake, exhaust - from start to finish and within a matter of just a few minutes know if anything is out of spec.. They can also reset your ECU computer and essentially start from fresh factory settings - then you drive normally and conservatively and the ECU will be in "learn" mode, which means it learns your driving style and tunes itself to optimize the driving experience. If you drive conservatively in learn-mode it will tune the vehicle for optimium efficiency.
I strongly suggest you take it to Nissan to have a full diagnostic check, it is a quick and easy process that can be extremely useful with a good chance of solving your issue. Good luck and let us know how it turns out.
