goodbye wrote:Holysheetman is right, resetting the window does work. I just did this on a 2003 Coupe with the window down a quarter problem.
The door panel is simple to take off, just the two plastic clips at the front of the door, one screw by the door release handle, and two behind the plastic trim piece that you pull the door closed with. That plastic piece just pops off from the bottom. The rest is just pop clips around the door edge. Took me about 3 minutes to take off for the first time. Probably a minute if I did it again. The reset switch sits behind a small black sticker about the size of a nickel right in the middle of the door. Here's the procedure direct from Alldata.
ResettingAfter installing each component to the vehicle follow the steps below.
1. Raise the glass to the top dead center. 2. While pressing and holding the reset switch lower the glass to the bottom dead center. 3. Release the reset switch and check the reset switch returns to the original position and then raise the glass to the top dead center.
CAUTION: Do not operate the glass automatically to raise the glass to the top dead center.
That has got to be pure coincidenceGoat_Wiz wrote:THanks. I will try that today. It is all of them. It worked before I installed the intake. After I installed it the auto up quit working, the auto down still works however...all windows.
