Auto trans shift sensor?
redbeardxxv
Car: 1992 240sx vert (work in progress and DD)
Ok, so I heard somewhere that there is a "shift sensor" on an auto transmission that will make it shift "like an aggressively driven stick"..... What's this about? Is it for real? Harmful to the transmission? If it is possible, and not harmful, can it be wired to a switch instead of permanently disengaged? (had an eagle talon that had a "sport" button that made the auto transmission hold gears for a bit longer) Anyone done this? :gotme
And hey, while I'm at it, The car has 98k on the odometer, but it works intermittently, so I 'd guess the real # is closer to 130-140..anyway, the transmission fluid looks good, was wondering if I should have it flushed just for the hell of it, that way I know all the fluids are new? I have always heard that changing a cars transmission fluid after too many miles have passed is actually bad for the transmission. I have no way of knowing when it was changed last, and I'm thinking "if it ain't broke....." Thoughts?
cbt240sx
Car: 1990 Nissan 240sx
Read this.
auto-transmission-mod-t466449.html
I believe that the pics are cut off and do not show the resistor they are talking about. It is located near the drivers side strut tower, along the top of the fender wall. Just pop the hood, you should see it.
:shifter:
guyaverage
Car: Nissan 240SX Convertible
Its the dropping resistor on the driver side, next to the coil. If you unplug it, it will set the transmission line pressure to maximum, severely firming up the 1-2 shift and milding firming up the rest.
Instead of unplugging it, go to radio shack and get a couple of the larger, ceramic 50-ohm power resistors, they are larger than the tiny 1/4-watt ohm resistors most people are used to. Replace your dropping resistor with one, or two 50-ohm resistors connected end to end, to firm up your shifts. I have been using 100-ohms for several years now and I like it. The stock dropping resistor is about 15 ohms.
Driving around with it simply unplugged, with line pressure max'd out all the time, is not good for long term reliability.
Yes, change the fluid. Dont do a power flush, or use anything other than atf. Just change it (several times if necessary) using the drain plug, or drop the pan and clean it (and the magnet), change the filter, and replace whatever drained out. The thing about not changing old fluid is a myth. Use either a generic Dex III/Merc fluid, or Mercon V. The Mercon V has different friction characteristics that can give a very slightly firmer feeling shift. You may not notice any difference though.
Again, if it were me, I wouldnt just unplug the resistor.... :nono:
redbeardxxv
Thanks guys, I'll look int the resistors, I wasn't too keen on unplugging it anyways.....and I guess I'll change the transmission fluid...as long as it's safe, I'd rather know it's new...
