auto transmission mod
dsm turned nismo
Car: 1996 nissan 240sx
is there anything I can do on the cheap to get firmer shifts or be able to manually shift my auto in my 1996 s14
S13k
Car: Mazda miata 99 NB
Nissan 240sx 91 s13
hmmm
HardDrifts4Lace
Car: ehhh about that.
like a new torque converter?
maybe its time to read the guides on how to a 5 speed manual transmission swap.
dsm turned nismo
HardDrifts4Lace wrote:like a new torque converter?
I mean like a way to increase line pressure or something? And I'm going to rb25 swap it in a few months I jus want a little firmer shifts for now?
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Really? You need "firmer" shifts for your stock automatic KA race car?
Just when I thought the world couldn't get any worse.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
Disconnect the rectangular sensor next to the ignition coil on the right. that will make the trans shift much harder
nismoracingsx
Car: 1993 White 240sx Coupe
just shift your auto manually...that alone boosts fluid pressure giving you a little more feel..
MAD02
Car: 1974 BMW 2002 Tii
Yup. That sensor in the photo above regulates the automatic transmission fluid pressure, if I remember correctly. It was there to give auto equipped 240's nice and smooth gear changes. I disconnected it on my old '90 240 auto and it shifted with authority! The automatic transmission still sucked, though.
dsm turned nismo
NISSAN240SX12 wrote:Disconnect the rectangular sensor next to the ignition coil on the right. that will make the trans shift much harder
So that won't have any bad effects? Like no shifts or anything bad?
NISSAN240SX12
1991 Toyota Supra
it shouldn't. but it wont matter that much if you are doing a swap. i wouldn't worry about how your trans is shifting. i still have a auto but i dont need it shifting hard cause i have a newer trans im my car. shift perfect!
dsm turned nismo
nismoracingsx wrote:just shift your auto manually...that alone boosts fluid pressure giving you a little more feel..
When I put it into first it still auto shifts?
dsm turned nismo
ILoveMyRHS13 wrote:Really? You need "firmer" shifts for your stock automatic KA race car?
What's wrong with wanting a little firmer shifts out of the stock trans? Until I can afford the swap I'm doing. And a firmer shifts r better on the trans clutches not alowing so much slip and I'm not running excessive power to produce a lot of shock load!
Darkness and Light
Car: 1993 240SX Fastback, 1995 240SX Coupe SE
Disconnecting the wire doesn't just feel firm, its jarring. On wet road with crappy tires going from first to second, the tires actually chirped at me. I wouldn't bother.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Psst. Torque converter have nothing to do with how it shifts.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
dsm turned nismo wrote:When I put it into first it still auto shifts?
it's an automatic transmission. wtf did you expect it to do? it does that so you don't ride it in first, at high rpms, for an extended amount of time, blowing something up.
i think you guys are over thinking what's possible in your mid 90's transmission that came in a "sporty" economy car. it's not a ferrari with a clutchless f1 transmission. it's a commuter car. you want more control of your transmission, do a manual swap, or buy one that already has a manual and sell the automatic.
240sxJoe91
Car: 1991 240sx Ka24de
Yea i say just wait until you drop the new motor in it and then drop a manual trans in it your car will be out of commission for a while anyway since your going to install the new motor so just go for the auto to manual transmission swap when you do your motor. But that's my Op..Good luck
KAbezon
Car: 1995 200sx
There is also this:
http://www.latentsolutions.com/suprastickuv.html
It is called the Suprastick. It was designed for the guys who have high hp Twin Turboed Supras (hence the name, lol), but can be used in almost any sport compact vehicle.
It is a standalone TCM, that can be programmed for shift points, line pressure, among a few other things, and works with a type of tiptronic system they offer, that can be installed anywhere on the car. I have a friend here in Phoenix, that has it hooked up to his Altima, and he uses the steering wheel volume controls to shift
pretty cool stuff
zenki-S13
Car: 1990 Nissan 240sx S13
this is fail
just wait till you do a swap unless your lying about it to sound cool
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Thats pretty awesome. I could shift with my cruise control buttons on my steering wheel. I might put one on my koop in the future.
dsm turned nismo
zenki-S13 wrote:this is fail
I'm definitely not lying to sound cool lol. Its getting a rb25 or 26 for sure I'm just waiting till I'm out of school in a few months so I have the money
dsm turned nismo
A lot of transmissions when its put in the first or low position will hold that gear until driver input says otherwise
Persona
Car: 97 Kouki
The car in your sig looks fail to me.
Get out if you dont have anything to contribute to the guys post.
Klits562
Car: white s13 coupe
i did this to my 89 today its interesting. First to second is really really hard but the rest of the gears r just a slight difference.One thing i really noticed though is that when i left off the gas my rpms drop straight to about a 1000, i dont lose any power, its remind me of in a manual car when your driving and you push in the clutch. Is that whats kinda happening here with my auto?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Not electronically controlled transmissions. They use electronic shift-points, with manual pressure backups. They do this so you dont burn the clutches for the engine. My work van is the same way. I can put her in low, but it will shift to second at WOT for a second or two.
dsm turned nismo
Darkness and Light wrote:Disconnecting the wire doesn't just feel firm, its jarring. On wet road with crappy tires going from first to second, the tires actually chirped at me. I wouldn't bother.
i just did it and it worked perfectly drove just like a shift kitted trans much firmer shifts and easily broke the tire in the 1-2 so i would bother lol
jdm_dean
Car: 1992 Nissan 240SX Coupe
Wow.
Dittoz7
Car: 1997 2f0WtY SE!
Well Since The Picture Posted Was Of A S13.
Guessing The Senor You Would Have To Unplug Would Be The Longer Of The Two Actual On The Distributer Cap Itself.
Right?
Would Try It Just To See The Results, But Mine Been Stuck On 2nd For Longer Then I Can Remember...
SirSilvia
Car: Sold both my babies
dunno about your auto, I tracked my auto coupe and it hasn't shifted out of gear. And I was redlining it, which stressed the engine so much I shredded the timing chain guide. Hitting 1st then 2nd, and approaching the turn, I let go of the gas and went to 1st then floored it again. Hard as hell, but drifting is possible. still never shifted out of the gear I put it in.
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
i'm so sick of this "swap to a 5spd bulls***"Transmission peiceshttp://www.bulkpart.com/Mercha...4R01A
Shift kithttp://www.summitracing.com/parts/TRG-RE4R01A-HD2/ trans-go shift kit review. http://npora.ipbhost.com//inde...c3a59 http://www.superior-transmissi...a.htm
people on here should really not post unless they can help.
dsm turned nismo
SirSilvia wrote:dunno about your auto, I tracked my auto coupe and it hasn't shifted out of gear. And I was redlining it, which stressed the engine so much I shredded the timing chain guide. Hitting 1st then 2nd, and approaching the turn, I let go of the gas and went to 1st then floored it again. Hard as hell, but drifting is possible. still never shifted out of the gear I put it in.
yea i figured out my prob binding likage to the trans not allowing me into manual first so it was still shifting into second then would stay in that gear
