According to the FSM, the transmission's total capacity is 11-1/8 quarts. However, if you're only planning on replacing the 4 or 5 quarts in the pan, what's the point?BlueC wrote:When I have the Z32 Differential installed on thursday, I also want to have the ATF replaced with synthetic. I've heard a lot of great things about Redline ATF, how many Qts will I need to have it replaced? Keep in mind, I had a flush done at the dealer probably 6,000 miles ago, so a flush really won't be in the picture quite yet.
Well, better late than never.BlueC wrote: I think i'm going to wait on the ATF fluid for another month or two, and then i'll do a complete flush, just intime for winter.
The differential will get sythentic fluid upon installation, i'll let the shop use their gear oils since I wont be able to get redline fluid out here sooner.
In MN winter, all synthetic will be much better on cold starts and in low temperature operation.elwesso wrote:My point is, id rather see you change your ATF with dino once a year rather than do synethetic every 1.5-2 years. Synthetic ATF 1 per year, probably overkill but you cant be too safe...
That's what i've heard, and thats 50% of the reason for switching to synthetic.maxnix wrote:In MN winter, all synthetic will be much better on cold starts and in low temperature operation.
94 Q45 wrote:I couldn't find it either. ? Maybe our resident expert with the search button will chime in here and save us all form our stupidity and laziness.bullittandy wrote:If you plan on replacing the ATF then there's a procedure for draining the pan, adding 3-5 quarts, running the car for two minutes, and repeat. I read a post about this where it takes 2 minutes to empty the pan. This may be worth your while.
Hi, I want to know where can I find the procedure on how to change the ATF and differential gear oil because I have searched around and could not find any information. Thanks for the direction.
For the differential, try this thread:94 Q45 wrote:Hi, I want to know where can I find the procedure on how to change the ... differential gear oil because I have searched around and could not find any information. Thanks for the direction.
