Well what my friend has in mind is getting the exact thread pitch bolts needed by using some tool to measure the pitch then finding that precise bolt at Ace Hardware.themadscientist wrote:DO NOT USE HARDWARE STORE BOLTS! They will often be the wrong thread pitch and hardness. You should be able to swipe bolts off other Nissan engines. Most of us have a coffee can or two of miscellaneous bolts as they are common sizes.
Oh believe me, if I could've gotten all the bolts in a bucket, I would've.TheMAN wrote: it's too bad you didn't dump all the bolts into a bucket at the very least, because finding them will be hard and time consuming at the junk yard, and will cost you a lot from the dealer
do yourself a favor and find yourself a copy of nissan fast and start looking up parts yourself and see what you are able to order here
there's various questionable places to get it from, so use your imagination
Thank you so much!TheMAN wrote:you'll want flange head M6x1.0 bolts for the oil pan... you can find them at ace or any parts store
if you search on ebay, you can buy OEM nissan flywheel bolts for the CA
Yeah I've ordered ARP rod bolts through him. I wouldn't be surprised if I bite the bullet and just order flywheel bolts and transmission bolts from him too, just for the peace of mind.ragenasian wrote:http://cgi.ebay.com/ebaymotors/Nissan-F ... 500wt_1182
I find this guy to be overpriced much of the time but he has the bolts.
Thanks for the advice, Tim. I'll come by soon to get said handful of bolts. You'll have to roll with me to Hazel Green (where the project is now) sometime soon to see the work in progress. That, and we gotta go mountain biking.r34 gtr wrote:A while back I had to order a bunch of m7 bolts for mounting my trigger sensor to my oil pump. They were ridiculously hard to get, and I had to order a bag of 50 to get the 2 that I needed. No idea if they will work for all the oil pump bolts, but you are welcome to come grab you a handful.
ARP has got you covered for the flywheel bolts (or ebay, where there are tons of OEM. I think OEM and ARP are pretty close in price though)
And I would just use hardware store bolts for the oil pan. Nothing under a whole lot of stress there.
Awesome, thanks man.TheMAN wrote:there are various S13 200SX PDF manuals floating around... they are scans.... it'll have most of the information you'll need... it covers the 4 port head EDM CA, but the 8 port JDM version... but there aren't enough differences to matter
There was some crud in the hole that the little guide post goes in on from the squirter. When my friend tightened it down to 25 ft-lbs, the ring of the squirter cracked. We're getting it welded back tomorrow.TheMAN wrote:how did you manage to do that? there are oil squirters on ebay too
Wow, yeah I read that after much googling.biosehnsucht wrote:The ARP CA kit not actually working on CA is an old issue:
to-all-you-arp-head-stud-users-t171021.html
Most of us ended up with I think SR main stud kits and used them for the CA head studs.
Code: Select all
Part code Desc Part #
11056 BOLT-CYLINDER HEAD 11056-D4200
11056C WASHER-PLAIN 11058-16A00
