sideways danny wrote:I don't see the big deal with ARB studs, why bother when MASSIVE power has been proven on standard bolts? the only metal head gasket I've ever seen blow in use rather than from mis-assembly (pro built SR20DET) was an ARP equipt engine. Standard bolts and an ACL race series head gasket going in my engine this week
So can the standard bolts, they are NOT stretch bolts, the FSM does not specify they need replacing. I've never had a single issue with standard boltsoriginalsin wrote:
the studs can be reused, i just ordered them, and will be using a felpro hg copper sprayed
The biggest problem I think some of you are having is crappy part#. I don't know what part # you all are using, but for those who are having problems, could you please post of the part #s for your studs, so that I can compare them to the part #s I use on my engines as well as customers engines, too.r34 gtr wrote:dee, ive done exactly what you said and it still leaked. i eventually used both sets of washers because after measuring the studs, it seemed like on 1 or 2 i was just tightening the nuts against the shoulder on the stud, instead of the head. even though the head/block surface is quite out (~7.5 thou total) it is leaking only a tiny amount. this is with a reused (and copper treated) nismo metal gasket and arp studs.
but please do whatever you guys think is right. mine is leaking after all, so i dont have all that much room to talk.
- Tim
What part # is that for and who told you it's the correct part #?originalsin wrote:i just ordered these 202-5402
Years ago I had the wrong part #, sent my bolt to ARP, and this application works perfectly in every engine I've installed them in; even the ones that didn't get machined.originalsin wrote:ok so dee, what part number are you running
and, should oem headbolts be able to go up to 300whp without problems?
OEM bolts can take more than 400whp. I did 332whp on an internally stock/used CA18DET using a turbo with a .48 rear housing, 20psi of boost, pump gas, and very humble mapping. We'll see how the car does with the same turbo, a ported head, Heavy Duty valve springs, and cams. So yes, it can be done and it wasn't the 1st time I've done or others around the world.originalsin wrote:ok so dee, what part number are you running
I see why not. I don't use it.originalsin wrote:this may be a dumb question but would loctite or some type of thread sealant be a bad idea?
I don't know about that gay stuff, Tim . But I'll re-send my previous email to you.r34 gtr wrote:alright then. wish i still had the box so i could confirm. if thats the case i may be needing some new ones.
dee, could you throw me the part no. you use? i didnt get your email the other day (hotmail blows). if you want to send it to [email protected] i would love you forever (not in a gay sense though. "i dont play that way. im not that way!!" - carl, athf)
- tim
Not the same as the ones in my invoice, but could very well work..r32line wrote:Ive just ordered ARP 202-4302. Is this the right part number boost boy?
