Asking before i get angry:Transmission
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Hey guys, as some of you may know back in august the third/fourth gear shift fork snapped and broke off rendering the transmission useless, not to mention the wierd hybrid no one knew what i had.
Anyways, i picked up an RB20DET transmission from JGY customs for 395 and it shipped and got here the same week, which im pleased with, but "I THINK" i may have a problem on my hands. The packaging left a bit to be desired but i think its decent, when i unpacked it, i noticed the shifter was out of the transmission which was good, but when i put dropped the shifter in with no c clamps, i can ONLY shift into first, and second gear, I tried rotating the input shaft to see if the gears were just snagged, but still no go. Am i just paranoid and i need to install it and give it a try....Or should i assume something like the SHIFTER FORK IN THIS ONE is broken.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Call up Jason.Ask him whats up with it.
Umm I know my transmission would shift into and out of all the gear when it was out of the car.(I swear I wasn't making any engine noises while I was doing it. LOL)
I really wouldn't put it in the car.
Kansei240sx
I called them up and the guy at the phone said, he shifted through all gears before he shipped it out. He said if any damage happened, it would've had to been during shipping with UPS and that it has happened recently to other customers. So then he told me to go ahead and get some fluids in it and just try it out and see if it loosens up. Im going to do that, but before i do, i might as well take it up to work and have the master technician in service look at it::Nissan:: since i work there.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
$395 for a RB25 trans? maybe thats the problem lol. Hey hit me up with a Email or on Aim when you get a chance I want to ask you about that ECU program that guys is doing for the ECU's.
Kansei240sx
Kansei240sx wrote:Anyways, i picked up an RB20DET transmission from JGY customs for 395 and it shipped and got here the same week,
Its an RB20DET transmission. Ill aim you here in awhile when i finish painting a few things.
Kansei240sx
I've taken the shifter plate off, and took a look inside to see if it was debris causing the shifter not to move, and it isnt.
I stick the shifter into first and second which it has no problems going into, and then, once i've got it in, i try to move either the input or output shafts, it doesnt move at all.
I cant move the lever to reverse, fifth, fourth, or third, and it wont even let me move it sideways in the middle of fifth and reverse...
BoostFab
Car: S13cp, S13fb, S14z
is hte shifter seated properly and clamped down; make sure the shifter is in a slant back direction?
Kansei240sx
Yes, its all properly put together.
I added some oil and held it a slight angle to keep it from leaking out the back, and i put a burnt up clutch on the input shaft to get it to spin at a decent speed.
IHere is an illustration of where i can and can't move the shift lever and its properly seated, lubed and in the right spot.
OpeLok
rebuild old trans. I did. Broke reverse/overdrive in my 20 trans. replaced with KA shift fork. Only syncros 1 and 3 I think it was would work with my rebuild kit for KA.
Kansei240sx
Not to be a d!ck, but im not rebuilding a transmission i just fvcking bought that i've never used which is supposed to have low mileage and work in the first place, i'd rather get punched in the d!ck....
Yellow4g63
JGY ftw
Eikon
Car: 71 240z, 93 Supra TT
you gotta put the clutch in silly!
j/k. sorry.. I'm sure you're not in the mood for jokes.
It shouldn't be too hard to find a couple of C clamps and get that shifter set in there properly. When you do that.. if it still doesn't shift.. I would ask for another trans or an insurance payout from UPS or whatever the dude from JGY says you have to do.
Sil240
Quick question???
Since the shifter was not in the transmission.How is it that UPS damaged the anything inside the transmission???
The only thing I could see is if something up up in the bellhousing and BLASTED the input shaft.Don't know what kind of damage that would do, but...... I doubt it would cause the problem you have.
But the easiest thing would be to get your $$ back from UPS. How much did they insure it for?You might even make a little more back.But it they didn't put enough to cover every penny you spent with them.
Get up in JGY's ***.They've tried to pull some BS with us twice before.
Kansei240sx
The shifter has all the proper C-clamps, and even if it didnt, it is still all the way down in there and would STILL move to the right side of the pattern, but it doesnt. There are two nice gashes...or scratches that look clean on the top of the transmission on the rear casing.
Trying to get money out of UPS is like trying to drive a car across the ocean.
Im going to figure out what the deal is here in a few hours, ill keep it posted.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
From my experiences with JGY in the past and many others also, I would not even come close to trying to squeeze money out of the shipper (UPS in your case). JGY is like an SSAutochrome in my book, except they charge way more for stuff that doesn't work at all. Also like the SSA group, good luck getting a refund or replacement from JGY.
Kansei240sx
Heeeeeeeeeeeellllllllll yeah!
I fixed it and it goes into all gears thanks to a friend off a local forum, he gave me a tip and i tried it out.
Basically i took the front cover off on the inside of the bellhousing and the three rods that poke out when you shift was stuck. The first and second gear rod was poking out half an inch or so... maybe not even that much. I lightly tapped it about 2-3 mm's and then it recedec into place with a "not braking" click sound.
Put it into first, then to second and it popped out again and tapped it back, then put it in neutral, then went 1st 2nd, 3rd, 4th, 5th, back to neutral, and then to reverse, several times perfectly, i am so pumped, ill have my **** back in and running this weekend.
Thank you guys for your efforts and tips.
rotorimp
Car: 02 Xterra, 60 IH Metro
What do you think caused that? was it dropped on the bell housing by UPS?
OKRB20DET
Car: 1990 S13 coupe
rotorimp wrote:What do you think caused that? was it dropped on the bell housing by UPS?
well i just assumed my transmission did that due to a rough *** ride half way across the USA.... so i just told him how i fixed my issue and shazaaaaam! thats the only thing i could think of is a rough *** ride...and they probably had the transmission bellhousing side down for a while at the shop..
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Good deal!
DrIft Ready
Car: 1990 silvia built sr..
I have the Same F..en problem with a sr swap i did this weekend...the motor was in a wreck in japan..i know this because i have pixs of the car..anyways..in nutrul the car is in reverse and in 1st and 2ed the car will just stall..that it ..???/well im going to mess around with it tomarrow ..but i have a felling im going to have to chang it out any updats keep me informed ..and ill do the same
Kansei240sx
Jesus christ learn to spell! lol!
Jfwy, yeah... sounds like either A. the shift forks are broken or its trying to be in more than one gear at a time, take off the front cover inside the bellhousing and then tap the rods that come out till they're all even.
l0nestar
2004 Toyota Altezza
Man, I quit worrying about the grammar and spelling used on forums a long time ago...
booboo
Car: 1991 nissan 240sx
that's cool that you got it to work
I just bought this 1991 240sx for 500 bucks.... the guy i bought it from he unhooked everything from the engine and the wire harness from engine when i was putting it back on i dont know were this plug goes. and this other wire look burnt. and it starts and idles up then back down and then dies.... so do u know about that plug and what does it go too.
Carl H
wtf does that have to do with a transmission?
booboo
srry dam
Kansei240sx
Well.... You guys wont believe this, and i feel somewhat stupid at the moment, but... JGY customs sent me a KA transmission.
The reason i know this is, because i have my OLD ka24de transmission off my old engine, andits been sitting around... So i finnally get my clutch and flywheel in, and we assemble it all and get to sliding the transmission JGY CUSTOMS sent me, "RB20DET" and we notice that the bolt holes dont line up at all and the dowel pin that sticks out off the block to line up the transmission doesnt go in either.
So not only did they send it to me with a leaking front cover and it not going into any gears than first and second, and MYSELF fixing it and re-sealing the leak, its the ****ing wrong thing. So i guess theres more down time to be had.
Just when i was getting progress. I WILL have a ****ing correct transmission from them, ill let you guys know what happens with this.
l0nestar
2004 Toyota Altezza
Kansei,That is... well, unbelievable. So far there is only one person that I know of who has had good luck with them, and he is a local guy with an NX2000. That is pretty appalling. It speaks wonders for their business practices and and how they operate / feel about customers. I was browsing their site, just for a laugh, and saw that they do in fact have used RB25DET transmissions.. for $1700.00 ! and a used Z32 MAF for $299.00! Ludicrous I say! I can only imagine what the quality of the welds on their mounts are like! I sincerely hope this gets resolved nice and peacefully.
Sil240
Damn.....
Call Jason and get up his @ss!!!!They just sold you a $400 KA transmission.Did you have a RB transmission before??
If so, get your $$ back from JGY and go to the Junkyard and get a KA transmission and swap the bellhousings.
Double check the procedure before you call them though.
Kansei240sx
I had a Hybrid VG/RB wtf transmission before, with the RB25 bellhousing so i cant swap it over. Unfortunately, im going to call them up in a few minutes and see what happens.
l0nestar
2004 Toyota Altezza
So, how did the calling go?
