Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Sun Apr 01, 2007 12:01 pm
Just FYI, jds, you wont be able to turn the output shaft if its in gear in first or second. If you can turn the driveshaft while its in first or second, then YOU REALLY have a problem. It takes alot of torque to move that *****.
Just think about it for a second. I put my Z in first gear on hills without the e-brake on because the cables are old. When i let the clutch in, it doesn't move. Same principle applies to try moving it when you have the transmission out.
Just take that plate off, tap those rods even across the three of them, and then move it in and out of all the gears a good set of times and put it all back together.
