ARRRRGGGGHHH Bellhousing help
Keachj06
Car: 1989 Fastback SR20DET
i cannot for the life of me get the 2 bolts at the top of the bellhousing off, its such a small fit and i can only get a socket and wrench in there wtf, how do you get these things off, iam torqueing the crap outta of em that is lifting me off the ground
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Drop the transmission crossmember, get a really long extension, a swivel socket, and a breaker bar, or Impact wrench, if you have access to air.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
I did it with a 1/4 ratchet, 12 inch extension, 3 inch extension and 2 u-joints. it was also about 5* outside that night.
Keachj06
ok the swivel socket sounds like a good idea i may try that.
Kraelic
Car: 89 240sx
I used a ratcheting box end wrench with 5 degree clicks, there was one bolt that I could only get one click on per movement, I had to put my hand in behind the intake manifold where the heater hoses go into the cabin and that one bolt was such a bear. Funny how after removing the automatic and putting the manual in I was able to get to the same bolt from under the car much easier to tighten it. Dang automatic was just too big to get it from the underside I tried, but I didnt think of a swivel bit.
