If no change wouldn't that indicate a problem?AZhitman wrote:Disconnecting the MAFS, however, doesn't change the behavior.
+1Tampa G35 Sedan 6MT wrote:you see a pattern? maybe it is the same thing? !
1+RED_DET wrote:Time for a new MAF. If you unplugged the MAF and received no change, then something is wrong with the unit.
Find a member with a 03 swap in his Mafs and see what happens??AZhitman wrote:I've been battling an issue on my G for over 2 weeks now, and I think it's about to get the best of me.
03 G35 6MT, Vortech s/c kit, tuned, headers, nismo exhaust, blah blah blah.
Couple weeks ago, it starts "missing" on acceleration (like a dead spot in the rpm range). I limp it home, start troubleshooting.
No boost leaks. Took off plenum and re-sealed it. Throttle body cleaned and re-sealed, all lines good, new plugs, no other obvious causes.
Car will start, then immediately dies. Throttle input won't keep it running, it stalls as soon as the engine fires.
Checked power and ground at MAF, all good. Ohmed the temp sensor, all good.
I cleared the codes, started it a few times until it picked up the codes again, and got P0102 and P0113 (MAFS and IATS - which are both incorporated in the same unit).
I'm at a loss, guys. Brainstorm a homey outta this problem?
Someone with a 03 should be able to help him trouble shoot by swapping parts though right?SteveTheTech wrote:Highly doubtful but it might work. I cannot find the wiring diagram for the MAF on the 07 Sedan since Nissan switched to HTML based wiring diagrams.
Piggy back controller, lets the user change the voltage return values of various sensors.http://www.splitsec.com/SteveTheTech wrote:What is the Split Second Box?
No problem man,SteveTheTech wrote:Huh that's neat. good to know that's, pardon my ignorance. I know that Factory stuff inside and out but the aftermarket stuff gets me sometimes.
Thanks for not burning me.
Did you have a 9 volt battery backup on your split-second?AZhitman wrote:2) The split-second box somehow "lost" its tune during the dead battery / battery swap.
