Are there any larger injectors for the Hardbody?
moneymike
Car: 1991 nissan d21 hardbody
i blew the ring lands on all 4 pistons
piston one being the worst
silveradobeast
Car: 94 HARDBODY 2.4 5 SPEED
94 d21 5 SPEED 4X4 EXT CAB
PARTINNG OUT A D21
keep us posted on the turbo i might do the same until i drop a tdi!
waynegarcia13
Car: 1997 Nissan Hardbody Pickup 2wd
2.4L: custom made cold air intake,
oil cooler, suspension lift, exhaust,
upholstery, stereo sys., paint
well i have a t25g turbo which is a smaller turbo from a sr20det i believe. So to the guy with the larger injectors what cold pipe are you talking about?
moneymike
the charge pipe your going to have to put coming right from the intake manifold
waynegarcia13
I already made one of those
moneymike
not bad
get any boost leaks coming from it?
i was thinking about buying a gato
waynegarcia13
I haven't installed my turbo yet i still need a manifold and injectors. but i'm pretty sure it's solid. I used a pretty thick gauged sheet metal and welded then added sealer to it and filled it up with water to see if it leaked.
moneymike
chilling idk about the manifold i got a sick a** tubular my boy found for me t3/t4 and thermal coated it
waynegarcia13
I'm gonna have to build one myself because i absolutely refuse to get rid of my A/C. I am just gonna buy the individual parts like the 90's,T's,flange etc. i am going to have to mount it at an angleto clear the low side a/c line and master cyl.
moneymike
it depends what turbo you go with
im running a 50 trim right now and i could have hooked up the ac but the line was touching the turbo if you go with something smaller it wont touch but it will be uber close
seang
Car: Ford Fiesta ST
Would a JGS log-style manifold be the best one? It seems like it would offer the most clearance, and the DIY kit would allow even more placement options because you have to cut the log and mount the flange, given the turbo will clear the other stuff (master cylinders, steering, etc...). It just seems like it would offer that extra bit of custom placement over an already-welded manifold.
waynegarcia13
I think I'm gonna go with this idea i found from a guy on KA-T
The guy said it cleared the a/c and it flow really good, it will be a hell of a lot cheaper and less time consuming than a diy mani. What do you guys think
moneymike
what the heck is that a turbo manifold with 2 runners?
StephenG
Car: 93 Nissan Hardbody 2wd KA24E 5spd
87 Nissan 200sx CA20E 5spd
moneymike wrote:what the heck is that a turbo manifold with 2 runners?
Looks more like a collector from a VG to me lol...
Theres always remote mount below the bed, right in front of the rear axle. You could pull fresh air from a box in the bed and your BOV would be super loud :)
waynegarcia13
Yes it's a turbo manifold, or it bolts strait to the manifold, it's a J pipe that this guy made coming off of the manifold, instead of using a turbo manifold. The turbo is still mounted in the same area but it's not in the way of the a/c. I think it's a great idea and i'm gonna go ahead and do it.
waynegarcia13
The reason that has 2 pipes is because the mani from a d21 has 2 pipes coming out of it. Look at ur trucks exhaust mani and u will notice there is a Y pipe bolted to the mani.
moneymike
ahhh so it bolts onto the stock exhaust manifold i get it now
waynegarcia13
it look s like this bolted on Image
It sits in a good spot and allows you to keep the a/c. I don't think it would flow too bad at all.
waynegarcia13
OK so i finally figured out the flow rate of the super charged Frontier injectors. Motor Man injectors says they are 324cc, and an ebay guy claims he has some that are 370cc. Either way even the 324cc can support 200bhp which is about where i want to be. If you think about it the s/c Frontier has 215 hp and thats a V6 s/c so 200hp isn't bad for a 4 cyl. Anyways i am gonna be using a T25 turbo and the 324cc or 370cc will be good enough for me. Tell me what you guys think about the flow rate info i have got.
moneymike
sounds good to me if you wanna go with bigger injectors ill sell you mine im thinking of going 910cc
