I doubt it. The answer is here in this thread:
http://forums.altimas.org/zerothread/318697
It looks like the OEM xenon bulb is a D2R. I would imagine that's a completely difference fitment than the halogen H11 bulb that the non-premium housing takes. Hence why we search for H11 conversion kits, and not just straight D2R kits when outfitting our cars for aftermarket HID. In addition, I would imagine that there very well could be some differences with the harnesses between the premium and non-premium cars.
I don't get what you mean by it "not making sense." The housings are clearly different. This is probably because the D2R OEM bulb has a reflective shield on one side of the bulb (hence the 'R' in the designator, which probably helps with cutoff and glare), whereas the halogen bulbs (and the H11 HID conversion bulbs) do not. I would think that if you took a OEM D2R bulb with a reflective shield and put it in a non-xenon housing, the beam pattern would be screwed up. The bulb would not be emitting direct light in all directions into a reflector housing that is designed to reflect and direct light from a bulb with 360 degree illumination.
If you are talking about the "housing" in regards to the bulb fitment, I don't think the D2R OEM bulb would screw into the housing the same as an H11. Bulb sizes are largely standardized across the industry. It has nothing to do with Nissan making a choice on how to manufacture their bulb fitment, and I don't think much development was needed. They just manufactured one type of housing to accept an industry standard bulb, and changed the mounting for the HID housing to accept an industry standard HID size. I can't argue on the 350Z, etc. because I just don't know. What I do know is that the non-premium AC takes an H11 low-beam, and I can say with pretty good certainty that this bulb size and mounting fitment will be completely different than an OEM D2R.
Easiest thing to do to get a better idea would be for someone who has factory HIDs to check to see if an H11 halogen can be screwed into the xenon housing, and if the harness is plug and play with the halogen bulb. I don't see that happening.
Modified by 121traffic at 11:46 PM 6/30/2008
