yellaspecV »
https://forums.nicoclub.com/yellaspecv-u5618.html
Mon Mar 10, 2003 8:41 am
SR20DET swap 'legal' question is going to get different answer in different states... If your state has smog inspections in most cases as long as you pass you should have no prob. Like one person said, "They dont care what kinda engine is in your car, as long as it passes" They arent the police, they are just doing a job!! In most states the law is that if the engine is different than what originally came in the car if must be of a newer year and falls under that years emissions regulations and specifications i.e. to make a simple example,,,, if you had a carburated '85 Camaro 305 you could swap in a 89 TPI 350 but not vice versa. But, you could put a 69 327 in the 85 but youd have to retain the emissions equip. and past 85 yr emissions specs.... Capice?
Sorry long explaination
