apexi safc 2 instalation
itzmadwack
Car: s14 ka-t 321hp/311tq
10psi
i have an apexi safc2 i wanted to install without splicing any wires!!
any tips? is there a harness i can use? like this
http://www.google.com/imgres?imgurl=htt ... s%3Disch:1
Tulsa_S-13
Car: 1991 SR 240sx
sr20det-safc-install-a-must-read-t380918.html :cool:
I suggest soldering it in if you're going to use it.
itzmadwack
10psi
thanks... i just got the car its pretty much stock and i have a intake and exhaust... i got the safc2 for 50$
pella
Car: 1995 240sx S14
itzmadwack wrote:thanks... i just got the car its pretty much stock and i have a intake and exhaust... i got the safc2 for 50$
just curious to know how and why you want to use a SAFC on a N/A KA.
rsmithdrift
Car: 1993 240sx fastback se.
prolly same reason I use it. Fuel mileage, control over the engine and diagnostic equipment. Plus the throttle position recorder is pretty sweet. lol. You can see how well your controlling the throttle through a set of turns or on launch.
Not too good for controlling the air/fuel ratio though honestly. It's basically just fighting the ECU all the time. You add fuel and the 02 sensor just tell it's to remove it again LMAO.
pella
Car: 1995 240sx S14
rsmithdrift wrote:prolly same reason I use it. Fuel mileage, control over the engine and diagnostic equipment. Plus the throttle position recorder is pretty sweet. lol. You can see how well your controlling the throttle through a set of turns or on launch.
oh ok. was just curious. would it be better to have this done via a good tune, so its set and not changing? is your car boosted? mine is still N/A but wanna put wideband 02, MAF, and fuel system upgrade. baby steps haha. thinkin on trying but not sure wich way to go. so you wouldnt reccomend it? ive seen lots of mixed reviews good and bad.
