Tampa G35 Sedan 6MT wrote:If you take the mid pipe off.. You will have essentially open Headers... and that is really loud... Trust me you need ear plugs to drive like that..
Get a after market muffler.. Like a nismo... But keep the stock mid pipe!
DJ
BAD idea. Stock midpipe is one of the worst parts of the exhaust. It is crush-bent, so its effectively only 2.25 or 2" inside diameter. A better MP will open flow a lot.
Sentientbydesign wrote:Misinformation... and lots of it.
HFC (High flow Cats) and straight pipes WILL change the exhaust note. USUALLY, it will add noise. Sometimes just volume, many times it will add rasp. I think of rasp as talking with a horse voice.
On the flip side, just about every G35 exhaust sound similar. I have a feeling that has something to do with the engine moreso than the exhaust itself.
If you listen to the stock exhaust on the G35 coupe, 350Z, and FX35, they all sound very similar. Most of the aftermarket exhausts for those cars also sound similar (though varying in volume significantly).
I've heard 2 or 3 out of dozens of exhausts for the G and Z that don't have that pseudo exotic note. I want one of those
So despite the HFCs and Straight pipes change, their change might not be enough to be a problem for you.
I'd go to a professional exhaust shop (not Guido or Jose's muffler shop, but a really exhaust shop) and talk to them about your various options. It would also be to your benefit to understand what your cats, mid-pipe, and muffler do and how they affect your exhaust note.
When 4drmadness comes back from India, shoot him an email and ask him. He's gone through a ton of exhaust variations. Unfortunately, he has a sedan which adds another variable into the situation, but the fundamentals should be the same.
SBD, High flow cats do not add rasp to the stock exhaust setup. The right HFC won't even add rasp to any setup. I have NO RASP and never had any with my HFC. They only make the stock a little deeper and louder. Its more of just an amplified sound. Test pipes on the other hand will rasp and normally quite a bit. I have heard of people wrapping them with header wrap and attenuating the rasp to almost nothing though.
The motordyne with the XYZ pipe really adds an exotic note. I had a guy at the Infiniti dealership tell me how much he loved the sound and how it sounded "exotic".
