anyone with pilot bearing removal experience?
24j0hn
Car: 91' 240sx with some babying to be given
i hear some people have taken 2 hours to do it, others 5 min...
whats the best and fastest way to remove the pilot bearing?
i was thinking of using my clutch alignment tool and putting electrical tape on the end to make it grab an pulling it... or should i get the too from an autoparts store?
Wat method did u use and how long did it take?
xX RB Xx
Car: SE3P, FC3S, FC3C.
hammer + screwdriver= no more pilot bushing.
that is what my friend taught me, who has 10+ years experiance on 240's and car mechanics.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
the above will do it. some times there a bi##h, but mainly, get the above tools, and manhandle it.
Xj220gt
Car: 1995 Nissan 240sx SE
easiest and safest way to do it is to rent a blind hole puller at autozone.
It will be out in 2 minutes.
try that first and if it doesnt work (it will) try the other stuff.
24j0hn
how would i use the hammer and screwdriver to get it out?
tmwnn
Car: '93 240sx
Do yourself a favor and rent the tool from autozone. Its FREE . You pay $40 and they refund you the money when you return it. I did it yesterday. It's my first time swapping a clutch, and it took me less than a minute to remove the pilot bearing. I don't even want to think of what a pain it would have been to remove the bastard without it while being cramped under the car
UneaK
i used a hammer and placed a pretty tall socket under it and like used it to hold the bearing in place to hit it with the hammer... took like 7 minutes...
24j0hn
so basically you just try to break it loose then pull it out
UneaK
it comes right off after hitting it
Future_gohan
Car: 91 240sx, 91 vert
We just did it today with a hammer and screw driver...took about an hour and a half but its out new clutch is in and it was worth it. lol
Future_gohan
24j0hn wrote:so basically you just try to break it loose then pull it out
No you make it your b**** and destroy it...mine was in 5 different pieces when it came out. lol
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
http://www.harborfreight.com/c...=4876 Use a wrench and not the t handle.
coolandy007
Car: 1990 Nissan 240sx coupe
This is the an old method and the one that worked for me after trying all the tools made for it.
Pack the pilot bearing hole with grease. grab a wooden dowel that fits nice and snug inside the pilot bearing and hammer it in. This will push the grease behind the pilot bearing which will in turn push it outwards. It's safer than chiseling at it since you could scratch up other stuff or miss and hit something else.
driftneil
Car: A pile of cars.
tmwnn wrote:Do yourself a favor and rent the tool from autozone. Its FREE . You pay $40 and they refund you the money when you return it. I did it yesterday. It's my first time swapping a clutch, and it took me less than a minute to remove the pilot bearing. I don't even want to think of what a pain it would have been to remove the bastard without it while being cramped under the car
I broke the tool from auto zone, it's a real cheap tool. Best bet is to get that 3 arm puller, and soak it with pb blaster.Btw, to the op...The bearing your tryng to remove is the manual, and not the auto correct?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
On swap day, removing the pilot bearing was the one thing I didn't plan for so we just used a dremel to cut it and then scooped it out. Took like five minutes but don't touch ANYTHING else down there. I would've gotten the tool if I had planned thoroughly. I dropped the ball that day!
24j0hn
well ima rent the tool and if it doent come out within ten pulls ima use the grease method, cuz i dont wanna f*** around with that stupid thing
driftneil
Was it 5 speed before, or auto?
killernoodle
Car: My daily: 2005 Cadillac CTS-V - pretty much stock
Brother's S13 project car: SR20det, wilwoods, suspension, q45 diff/axles, 315s out back
The thing in place of the pilot bushing from an auto KA is steel and usually impossible to remove, even with the special auto zone tool.
Its the biggest PITA we had doing his 5 speed swap.
I had to dremel my buddy's out.
driftneil
killernoodle wrote:The thing in place of the pilot bushing from an auto KA is steel and usually impossible to remove, even with the special auto zone tool.
It's actually easier pulling the auto pilot out, then the 5 speed. With the auto, just spray it with pb blaster. Then grab it with a pair of vice grips, and have a bud spin the crank bolt. It will spin right out.
Harman850T5
Car: 2003 350z
I'm in the same boat right now, I removed the auto pilot bushing with a pipe wrench and a breaker bar on the crank in about 5 minutes after many failed attempts with a pilot bearing removal tool. After that I found a manual one all beat up behind that.
Matco makes an awesome tool that our distributor says a lot of guys love, and I'll find out how I like it next Tuesday when it gets here.
It's Part#: CP55600
and a link for it http://www.matcotools.com/Cata...36678 it's on the top
LeD ippen
Car: 1993 Nissan 240sx SE
I used a small slide hammer :X came out in a few hits.
S13Teddy
Car: R32 Skyline, S13
I used a blind hole puller/slide hammer for both the pilot bearing and A/T adapter. It was much easier than using a stupid pilot bearing puller which is completely worthless, by the way.
sloweighty
Car: sileighty
the funny thing about the pilot bearing is that when i would hear this humming noise coming from trans and when you step on the clutch the noise stops and i have read forums that tells you to replace the pilot bearing and the noise would stop but every time i replace mine the noise keeps on coming back.......why is that?
ILOVESILVIA(S13)
Car: 93 Ca18det Hatch, 03 Subaru WRX Wagon (daily), Subaru Legacy Limited GT (daily)
Yep, just pack that b**** full of grease like coolandy007 said. I tried it myself and it comes out so easy.
driftneil
Harman850T5 wrote:I'm in the same boat right now, I removed the auto pilot bushing with a pipe wrench and a breaker bar on the crank in about 5 minutes after many failed attempts with a pilot bearing removal tool. After that I found a manual one all beat up behind that.
It's Part#: CP55600
What do you do with that tool? Shoot grease in there?
Harman850T5
Car: 2003 350z
driftneil wrote:What do you do with that tool? Shoot grease in there?
Yea, you just screw it into the pilot bearing, then hook a grease gun up to the grease fitting and have at it.
driftneil
That is frekin awesome! Im ordering one.
joe3180
Car: 89 240sx, S13 sr20det, silvia conversion
removed it with a blind hole puller took 15sec after it was in sight. borrowed it from my local auto parts store...easy
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
LeD ippen wrote:I used a small slide hammer :X came out in a few hits.
Yes, it shouldnt take more than 30 seconds to remove with a slide hammer and appropriate end piece, no other tools required.
95silvia14
Car: 1995 240SX, 1993 s13 coupe
thats what i did was pack it with grease and used a rod that sucker came right out in a min
